Stall at Idle.
Old May 12, 2008 | 10:15 PM
  #31
chet's Avatar
chet
Default RE: Stall at Idle.
if you could link me it would be much appreciated. My 02 sensors should be in tomorrow so when they get here i will put them in and let you know how it does.
Old May 13, 2008 | 01:53 PM
  #32
murph111's Avatar
murph111
Junior Member
I'm gonna throw this suggestion out there. I'm not sure if this is happening to you but I had the same problem when I would come to a stop the speedo would go from 10-15 mph straight to zero and would sputter and stall. It ended up being the speed sensor at the top of the rear differential, a $45-$50 part if you do it yourself.
Old May 13, 2008 | 11:33 PM
  #33
sst_chick's Avatar
sst_chick
I am having very similar problems to yours chet, same stall, same sucking noise through intake...I have replaced O2 sensors, worked for a while, then I had to replace the catalytic converter, it still doesn't run properly. Mechanic cant make head nor tail of this issue. Please tell me if you get yours running properly, I really am at a loss as I cant drive the truck as it cant idle for more than a couple of seconds, I have to put it into park and rev the engine at a light to keep it running. Its getting worse and Im not getting a code. I would really like to hear what worked, thanks!
Old May 14, 2008 | 02:09 AM
  #34
Mudbone25's Avatar
Mudbone25
heres the link for cleaning your Thottlebody
Old May 14, 2008 | 07:35 AM
  #35
tomwom's Avatar
tomwom
ORIGINAL: sst_chick
I was having the same problem. After the 3rd IAC my mechanic noticed I had a bad cell in my battery, he replaced the battery and put a new IAC in and now all is well. He told me that having the bad battery was the reason the electrics in the IAC was going bad. I don't know if that was really it or just a coincidence, anyways, have your battery checked.
Old May 14, 2008 | 07:50 AM
  #36
chet's Avatar
chet
I tried having my batt. checked and they always tell me its not fully charged so they cant check it.
Old May 14, 2008 | 07:40 PM
  #37
RangerMateo's Avatar
RangerMateo
ORIGINAL: IndyRamMan
The blind leading the blind lol.
Off topic, I know, but I just had to hijack the whole "Blind leading the blind" thing. I'm at Vance, which most people know is a pilot training base...what most people DON'T know is that it is also a RAPCON (Air Traffic Control) training base. So you have student controllers controlling student pilots. It makes for some interesting stuff on the radios...
