oil changes....read....
Old May 14, 2008 | 01:22 AM
  #21
ripto's Avatar
ripto
Default RE: oil changes....read....
ORIGINAL: aim4squirrels
Ripto,
If you've always run dino oil, I'd suggest you do this before you run syn:
Run one more run on 4 qts dino oil and 1 qt Marvels Mystery Oil to desludge the engine before you run the syn. I ran Dino for 60k or so before I switched to syn and when I did, the Syn pulled all the sludge out and polluted the oil something fierce. MMO will do the same thing, but it's much cheaper. You can then run a standard syn for 5K or so with no problems.
Thanks, I'll give this a shot (did not realize dino oil is conventional oil, lol)
Old May 16, 2008 | 01:14 AM
  #22
heavyduty1983's Avatar
heavyduty1983
yea steve i run royal purple in my truck to0 i pay like 7.50 here in central texas, but it works real well
Old May 16, 2008 | 09:01 AM
  #23
Timb75's Avatar
Timb75
I saw a dyno test between Quakerstate and Royal Purple on a show called "Horsepower" on Spike Tv. They took a newly built V8 engine filled it with Quakerstate, ran a dyno. Then drained it and filled it with Royal Purple and ran another dyno. The Royal purple boost the engine by 8hp. Not that big of a deal but an extra 8hp just from oil. Why not?
Old May 16, 2008 | 11:12 AM
  #24
hometheaterman's Avatar
hometheaterman
ORIGINAL: HammerZ71
ORIGINAL: hometheaterman
Sounds like a good deal. Kind of makes me wish I used Mobil 1 instead of Royal Purple. Oh well.
Found a fantastic dealat Advance Auto on Royal Purple (they are running the 5 Qt. Jug of Mobil 1 and filter deal also), but it's only on 1 grade and probably not one you'd use...
https://dodgeforum.com/m_1309472/tm.htm
As far as the switch over from dino oil to synthetic, I've always done an oil change from the dino oil to a 50/50 blend product for 3k miles, then went to a full synthetic for the next change, usually Mobil 1 and changed it every 5k thereafter. However I've recently experienced a very good mpg gain in my Grand Cherokee (bought with 61k on it) by putting Royal Purple in the engine and both diffs after using the blend for the first change. So I decided to switch from Mobil 1 to RP in the truck to see if lightning could strike twice. I've also decided to go to 6k between changes with the RP in both vehicles, which makes maintenance easier for me as I rotate the tires every 6k and can now do it all at once...
I remember ours had a few on clearance like that but none of them were the ones I used. I didn't see 5w-20 at ours. Maybe I should have checked others. I wonder if any would have it. Ours didn't seem to normally carry it anyway as I usually had to go to Napa to get it.
I use 5w-20 RP in the 06 Accord so I wouldn't have minded getting some for $5 a quart.
