removal of decals....
Old May 12, 2008 | 02:55 PM
BadHab1t's Avatar
BadHab1t
Default removal of decals....
what is the best way to remove my decals off my truck ...i.e. the gray pinstripes and the dodge ram decals on the side they are all vinyl decals and the pinstripes are cracked so they are a ugly site id like to remove these and wax and buff my truck out so it shines nice i also purchased gen 3 embems a while ago and need to put them on i cant wait to get it painted so ill put em on and well when it gets painted well deal with it then.... i dont want to scratch the paint anymore than it already is theres gotta be a way to do it .......anyone ......j
Old May 12, 2008 | 03:16 PM
Dedmeat1's Avatar
Dedmeat1
Default RE: removal of decals....
Hair dryer and fingernail
Old May 12, 2008 | 05:17 PM
wvjefo's Avatar
wvjefo
+1 Dedon the hair dryer, Fingernail to start Then just peel it off. A little Goo Off from parts store cleans it up nice.
Jeff
I did get blisters on my fingers so be carefull. Hair dryer does get hot
Old May 12, 2008 | 08:53 PM
BadHab1t's Avatar
BadHab1t
like i said the pinstripes are cracked vertically as there on horizontally thatll be the pain in the *** part any ideas on what would make that somewhat easier?.......j
Old May 13, 2008 | 12:17 AM
98cherryram's Avatar
98cherryram
OOOHHH, i can actually help with this one, go to the local sticker shop and they will have this spray on liquid that basically strips that stuff off no problem, my brother makes decals for a living so I guess I can ask him for the name of the stuff, ill get back to you on that though. But yeah, if you want to find out sooner then just run to the local shop and they will help you out.
Old May 15, 2008 | 10:31 PM
BadHab1t's Avatar
BadHab1t
i asked my buddy about some liquid **** like that he said i dk what ur talkin about peelin stripes a pain in the *** i make my **** workers do that i dont have patience enuf so i need to know a name of it plssss......
Old May 16, 2008 | 12:50 AM
DamascusKnifemaker's Avatar
DamascusKnifemaker
Go down to your local Auto Body Supply store. They will have Stripe and Decal Remover. Use per the instructions and scrape offending stripes and decals with a plastic scraper. Goof Off, Opps or Goo Gone should get off any remaining adhesive.
Old May 16, 2008 | 01:40 AM
hometheaterman's Avatar
hometheaterman
WD-40 seemed to get the old glue off for me fairly easily on the small thing I took off but goo gone or something might work better. I'd use a heat gun or hair dryer to heat the logos up then maybe pull them off or use a heavy fishing line to get behind it. There are a few write ups on this.
Old May 16, 2008 | 11:20 AM
CSCustomCars's Avatar
CSCustomCars
I had an issue with broken pin strips once as well.there was a black stripe, and a silver stripe, and the silver was broken so many time, I gave up on the goo gone. So, I used a buffer, 5 minutes, and they were off. Made it a lot easier. Just be careful with the buffer. if will take them off easily, so you don't need to sit there with it. Just keep it moving.
