Fastman TB
Old May 14, 2008 | 01:58 PM
doug15's Avatar
doug15
Default Fastman TB
I am thinking of getting a new throttle body and i was wonder what size to go with? I was looking at the fastman tb and they have the 50mm and the 52 mm, which one would be best for my truck. I have a 98 ram with a 318 and there is a CAI and a superchip on it.
Old May 14, 2008 | 02:01 PM
hometheaterman's Avatar
hometheaterman
Default RE: Fastman TB
Isn't the 50mm usually recommended for the 318 and the 52mm for the 360?
Old May 14, 2008 | 02:51 PM
Blaydrnnnr's Avatar
Blaydrnnnr
Yes.. in general, the 50 is recommended for the 5.2L...the 50 works well on both.... but you can use the 52mm on the 5.9L. I am running it. Anything bigger then the 52mm is not recommended unless some significant modifications have been made.. ( like a cam, bigger heads, fuel injectors..etc..)
Old May 14, 2008 | 03:01 PM
steve05ram360's Avatar
steve05ram360
+1 on the 50mm for the 318... it is an awesome upgrade.
Old May 14, 2008 | 10:21 PM
turkeyhunter1962's Avatar
turkeyhunter1962
When I bought my Fastman, Dan installed it himself. We talked about the fact that I had planned on replacing the 318 with a 360, but was doing so for towing performance not raw horsepower.
His recommendation was the 50mm for the 318 and for my 360 for towing. The 52mm would lose me a little torque down low for pulling.
However, that being saidonce my 4.10 gears are in I am going to upgrade to the 52mm to match the rest of my setup. The 4.10's will like the larger tb.
Old May 14, 2008 | 10:54 PM
steve05ram360
when I put mine on (52mm) I didnt seem to loose any low end torque. when I went back to stock though when I sold it, man was that added bump missed...
Old May 14, 2008 | 11:13 PM
doug15's Avatar
doug15
yah i sort of thought the 50 mm was the right one to go with but i wasn't positive. Is there any other throttle body's that anyone would suggest that are good for the 318 besides the fastman.
Old May 15, 2008 | 12:32 AM
jasonw's Avatar
jasonw
Site Moderator
You may find some just as good, but they will be a lot more expensive. Holley makes some, for example, but they cost about twice as much as a Fastman.
The Fastman's TBs, IMO, are the best. I have not heard a single bad thing about them.
Old May 15, 2008 | 10:55 PM
steve05ram360
ORIGINAL: jason.w
+1... fastman is the only way to go...
Old May 16, 2008 | 02:50 AM
pavester's Avatar
pavester
link?
