Transmisson problem after oil change
Old May 20, 2008 | 02:34 PM
timsalas's Avatar
timsalas
Default RE: Transmisson problem after oil change
I put 7 quarts in mine, I only let the thing drain for about 10 to 15 minutes, so there was probably another 2 or so qt in there of the old stuff so I think mine has a total of 9 qt. Did the manual say 2qt or 2 liters? Just curios might be confusing if it was in liters, which would 8 qt total? LOL I dunno
-tim
Old May 20, 2008 | 09:53 PM
theviper90210's Avatar
theviper90210
well I got a total of 6 in there tonight and tried the same thing with forward and reverse and the trans worked like it was supposed too. I have more oil if i need it and will drive it in the morning to see how it does. Thanks for the help guys.
Old May 20, 2008 | 10:17 PM
aim4squirrels's Avatar
aim4squirrels
ORIGINAL: timsalas
-tim
4 quarts are in a gallon. A 2 liter bottle of soda isn't as big as a gallon of milk, A quart and a liter are roughly the same size 1 gal= 4 qts= 3.89 liters.
a typical pan pull is 6 quarts or so. Let it drain longer (overnight) you'll get more. An extra deep pan could add as much as 4 more quarts.
PA-13 quarts sounds really high, did you pull the check valve in the tranny line going to the radiator?
Old May 20, 2008 | 10:37 PM
padodgeram's Avatar
padodgeram
ORIGINAL: aim4squirrels
ORIGINAL: timsalas
-tim
Rember i got a deep trans pan plus a cooler...
Old May 20, 2008 | 10:49 PM
hometheaterman's Avatar
hometheaterman
With my 8 and 1/2 to 9 quarts I do have a cooler and the check valve is removed. Will this make it take more?
Old May 20, 2008 | 10:51 PM
timsalas's Avatar
timsalas
Aim, LOL was thinking like European I guess LOL. ( in Dutch )
But yer right meh LOL
Old May 20, 2008 | 10:54 PM
aim4squirrels
yes, the check valve will let the radiator and stock aux cooler drain backward and out of the tranny.
PA that makes a lot more sense. So does that whole system now run you 20+ quarts?
Old May 20, 2008 | 11:00 PM
padodgeram's Avatar
padodgeram
just 13 quarts
Old May 21, 2008 | 11:30 PM
theviper90210
question do yall drive it for a while and then let the truck sit for awhile and let the only drain back down and then fill from there?
Old May 21, 2008 | 11:38 PM
padodgeram's Avatar
padodgeram
drive for a little then check the level while running in (N) or let it idle till hot and check it in (N)
