Lincoln electric fan ?'s
Old Jun 1, 2008 | 08:26 PM
32spec's Avatar
32spec
Default Lincoln electric fan ?'s
My buddy was cleaning out his garage and gave me an electric fan from a mid 90's Lincoln Continental 3.8 v6. Is this the same fan as the Mark VIII fan? And will this fan keep my 5.9 gasser cool? Thanks.
Old Jun 1, 2008 | 08:31 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Lincoln electric fan ?'s
Is that the one with the Flat fins or the s-curved fins? The Mark VIII fans are flat, triangle shaped fan blades. The S curved blades move about 300CFM's less.
If you tow heavy loads or do a lot of hard hill climbing, I wouldn't go under 4000CFM for the rated fans. I think that Mark VIII fan is right about 3750CFM and they draw about 35 amps so you might need to upgrade the alternator.
Old Jun 1, 2008 | 08:42 PM
32spec's Avatar
32spec
It has s-shaped blades and it 16 inch diameter
Old Jun 2, 2008 | 08:17 AM
IndyRamMan's Avatar
IndyRamMan
S shaped blades, need to get a 75 or 80 amp 4 or 5 post relay. Good luck finding one they are tough. Dont need to upgrade the alt.
Old Jun 2, 2008 | 03:13 PM
32spec's Avatar
32spec
Would I be able to use the relays out of a Continental with a 3.8 L?
