Starting/Fuel Mileage prob
Old Jun 8, 2008 | 12:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Starting/Fuel Mileage prob
lol ! Had me wondering until I read he cleaned the TB.
Old Jun 9, 2008 | 09:46 AM
DodgeRam2500CTD's Avatar
DodgeRam2500CTD
Oh yea srry bout that guys....yea it is a gasser 360......gonna see if i can get the cap and wires and ima change the plenum gasket if i can find it......
Old Jun 9, 2008 | 07:12 PM
DodgeRam2500CTD
got the gasket replaced.....wires, rotor, and cap......couldnt find a kit with the new pan so i just got the gaskets for now and replaced them.......It runs like a top......Im gonna replace the cat as soon as i get the money.....One problem tho.....the guy that helped me broke the plastic piece that connects the cable goin down the back of the motor to the throttle......Idk where to get another.....nobody has one......truck is hunting for gears right now until i can get that one piece.....otherwise shes good to go.......thanks a bunch guys i really appreciate it
Old Jun 9, 2008 | 07:17 PM
aim4squirrels's Avatar
aim4squirrels
If you have the inner part of that piece, use a zip tie to hold it in place for now.
Old Jun 11, 2008 | 06:07 PM
DodgeRam2500CTD
zip tie wont hold.....the plastic piece keeps slipping off.......im guessing it goes down to the tranny.......Got one on the way from the dealership....$50 but atleast it will be shifting right again......Spose to be here friday or monday.........Starting the whole take longer to start thing again.....I have no idea how to check the fuel pressure regulator so if anyone can point me in the right direction.....Btw....new fuel pump bout 4,000 miles ago so i hope its not the prob.....thanx
Old Jun 19, 2008 | 12:32 PM
DodgeRam2500CTD
Ok, got that new cable in.....it shifts kinda hard and likes the lower gears but im guessing thats because the cable is new and just needs to be used and broke in and then it will go back to normal.........Still taking quite abit longer to start.....Can anyone point me in the direction of the Fuel Pressure Sensor or whatever it might be? thanx
Old Jun 19, 2008 | 03:25 PM
zman17's Avatar
zman17
The new TV cable needs to be adjusted correctly.Or you will do damage to the trans.
Old Jun 19, 2008 | 03:31 PM
zman17's Avatar
zman17
And as far as the hard starting goes it is usually the fuel pressure regulator . But can also be leaking injectors. You need to do a fuel pressure leak down test by isolating the the regulator from the injectors .
Old Jun 19, 2008 | 03:43 PM
aim4squirrels
The correct way to adjust the cable is so that the TV cable and the throttle cable both move at exactly the same time. Grab a hold of the throttle mechanism and work it very slowly back and forth and watch both cable ends, when the TV cable and throttle cable both move at exactly the same time. you've got it. There is only a 1 mm +/- tolerance for this.
Old Jun 21, 2008 | 03:20 PM
DodgeRam2500CTD
ORIGINAL: zman17
No idea....lol.....any DIY pages for this?......sry but i dnt rly kno too much about the fuel system so I just want to make sure how to do it b4 i screw anything up lol......if the regulator is on the fuel pump assembly then shouldnt it be covered by the warranty on the pump?.....its only about 7-8 months old.....so idk....
