Pully Tensioner/Idler Pulley
Old Jun 17, 2008 | 10:18 PM
05DodgeRamHemi's Avatar
05DodgeRamHemi
Default Pully Tensioner/Idler Pulley
Would an idler pulley make a weird noise inside the cab if it was bad? There has always been this annoying grasshopper sound that comes in through my cab when the engine runs, could this be causing that noise?
Old Jun 17, 2008 | 10:31 PM
hometheaterman's Avatar
hometheaterman
Default RE: Pully Tensioner/Idler Pulley
Don't bad pulleys usually make a squeeling type noise? Is that what your trucks is doing? Most time I've heard of them being bad it's been a squeeling type noise.
Old Jun 17, 2008 | 10:55 PM
aim4squirrels's Avatar
aim4squirrels
Mine chirped like a cricket at regular intervals.
Old Jun 17, 2008 | 11:33 PM
atcsat64's Avatar
atcsat64
Yes, just replaced my tensioner, and the sound started as chirping and quickly went to squealing. It's easy to check though, take the tension off and feel for any play. My bearing was so bad I can't believe it stayed on...
Old Jun 18, 2008 | 01:17 AM
engineblock's Avatar
engineblock
test it first put WD-40 on one pulley drive it, if its not that one try the other one then you will really know
Old Jun 18, 2008 | 08:07 PM
05DodgeRamHemi
Awesome, thanks for the tip.
Old Jun 18, 2008 | 08:28 PM
aim4squirrels
Neon,
You do know that the idler pulley and the belt tensioner are 2 different pulleys, right? Not meaning to be demeaning.
Old Jun 20, 2008 | 10:47 PM
kowboydmac's Avatar
kowboydmac
my squealing had to do with the wrong belt. I had a 6 rib on instead of the required 7 rib. mine is a 5.9L so i assume your's would be the same.
