can somebody shed some light?
Old Jun 21, 2008 | 10:04 AM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: can somebody shed some light?
He says he checked it in his first post, but I'm wondering how ? I do it with a vaccum gauge by blocking off the breather hose and pcv hose and check for pressure at the dipstick tube.
I also wonder what he has for gears?
And since it's a 98 , if the plenum gasket was never replaced it is almost certainly no good.
Old Jun 21, 2008 | 11:52 AM
  #22
CySlyde's Avatar
CySlyde
remind me not to go to 408's friends shop. some one did that to my vehicle they would be buying me a new part.
a lot of places will tell you to tap on it... if you hear it rattle, then theres a lot of loose parts in there, and it's potentially clogged... I never liked that method. two best methods are to pull it down and visually inspect it. and put it on a flow meter which almost no shop has. or do the temp method.
Old Jun 21, 2008 | 12:38 PM
  #23
zman17's Avatar
zman17
What 408 is talking about is a back pressure test. He left the part out where you hook up the gauge.
Old Jun 24, 2008 | 06:31 PM
  #24
sk8ordie's Avatar
sk8ordie
ok just did the temp test that steve05ram360 suggested : drove 10mi to get cat in working temp did not have anyone help me so it just idled: used fluke T52 thermometer w/ pipe clamp sensor
486.7 f in
500.2 f out
from what i read is that if out is higher than in then it is good but i thought it would have more than 13.5 deg. difference.
does this mean that it is getting ready to go? i think im gonna try it again at my friends house when i can get there and try it again @ 2k rpm. i dont think i can trust my g/f to keep it @ 2k while im under there im gonna do the cap , rotor, and wires next pay day. if it is the cat where can i get one that i wont have to sell my arm for? its dual in single out stock size 2.5 out. once again i appreciate the info.
Old Jun 25, 2008 | 09:41 AM
  #25
sk8ordie's Avatar
sk8ordie
anyone?
Old Jun 25, 2008 | 09:47 AM
  #26
zman17's Avatar
zman17
You really need to get someone to hold it at 2000rpm. And it should be atleast 50 degrees difference at that rpm. And if your worried about getting run over, set the e brake and lay length wise under it not sideways! lol
Old Jun 25, 2008 | 10:25 AM
  #27
steve05ram360's Avatar
steve05ram360
ORIGINAL: sk8ordie
486.7 f in
500.2 f out
nope, looks good to me. the idea behind the 2000 rpms is to see it with good flow thru it. i'll be that when you do it with your friend you'll see a greater delta in vs out. your GF should be fine to hold the rpms while your under there, its not a big deal. and the 2000 rpms is not set in stone, again it's just to get good flow thru the cat.
