Magnaflow Cat
Old Jun 19, 2008 | 01:24 PM
  #21
hometheaterman's Avatar
hometheaterman
Default RE: Magnaflow Cat
Thank you for telling me I only have 1 o2 sensor. I hadn't even looked at it. I went down to check it out when I saw you said that and sure enough I only have one. I called to cancel my order and they said they would send a request and cancel it if it hadn't shipped. If it had I could return it. I then called the dealer and it looks like the 01 models have 2 different setups. Mine only has one 02 sensor. I'm going to see if any parts stores have one for mine but it may be a dealer item idk.
Old Jun 19, 2008 | 01:25 PM
  #22
hometheaterman
This is the cat I got.
http://store.summitracing.com/partde...rt=MPE-94109CA
Old Jun 19, 2008 | 01:53 PM
  #23
hometheaterman
ORIGINAL: jason.w
This is what most Dodge Rams 94-00 would need for a direct fit comverter.
Is that what I should have gotten? I was hoping I could have mine cut right where it's welded now and just a round one welded on.
Old Jun 19, 2008 | 02:14 PM
  #24
MEINEKEMAN1's Avatar
MEINEKEMAN1
ORIGINAL: hometheaterman
That converter will not work on your vehicle.You will need the one that Jason posted.Dual in,single out.MagnaFlow number is 94037
Old Jun 19, 2008 | 02:24 PM
  #25
hometheaterman
Thanks. So I guess I need to make another call to Summit to get the right one. Will that one for sure work if I get the one he posted?
Old Jun 19, 2008 | 02:27 PM
  #26
hometheaterman
So basically this is the one I have to get? http://store.summitracing.com/partde...p;autoview=sku
It looks like they are oos anyone know of anyone else that carries these?
Old Jun 19, 2008 | 02:30 PM
  #27
MEINEKEMAN1
Yes sir,thats the one.
Old Jun 19, 2008 | 02:39 PM
  #28
hometheaterman
I just noticed that says it has a single inlet and a dual outlet. Are you sure thats what I need? Don't I need a dual inlet and single outlet? Thats what I have now. What size inlet and outlet do I need? Hoping I can go ahead and order this thing shortly.
Old Jun 19, 2008 | 02:48 PM
  #29
hometheaterman
4wheelparts says the 94047 is a dual 2" inlet and single 3" outlet but Magnaflow's site tells me the same thing you do that I need the 94037. Have you personally installed these? Which do I need? Summit says both are single in dual out but 4wheel parts says the 94047 is dual in single out. I'm so confused as to what I need here.
Old Jun 19, 2008 | 02:56 PM
  #30
zman17's Avatar
zman17
Retired Moderator - RIP
IMHO that is a misprint!
