Transmission Temperature Sensor
Old Jun 23, 2008 | 05:06 PM
WD OPN Throttle's Avatar
WD OPN Throttle
Default Transmission Temperature Sensor
Ok, I have to replace the trans temp sensor, but I can't find it. Can anyone tell me where I can find it and how to get to it?
Old Jun 23, 2008 | 10:42 PM
robinbobin's Avatar
robinbobin
Default RE: Transmission Temperature Sensor
if its the 5.9 remove the alternator its the thing with wires to the right of the gooseneck where the top radiator hose goes. id replace the t stat while ur at it
Old Jun 23, 2008 | 10:44 PM
WD OPN Throttle
I wish I were so fortunate. My ram has the 5.2. Is the sensor in the same place?
Old Jun 23, 2008 | 10:54 PM
robinbobin's Avatar
robinbobin
not sure ill grab my haynes right quick and check it out for you..give me 5-10
Old Jun 23, 2008 | 11:04 PM
robinbobin's Avatar
robinbobin
yup should be in the same spot.. one thing... i just replaced mine and my old unit had 2 prongs ..the new one advanced auto gave me only had 1 ...and its not working so i would check it out make sure you get the new one with 2 ...or maybe i dont have it connected good enough...just a lil warning..i could be wrong about that tho
Old Jun 24, 2008 | 12:08 AM
padodgeram's Avatar
padodgeram
I mite be wrong , buttttt why would a trans temp sensor be on the block ??? wouldnt it be somewhere around the trans ??? I mite be wrong but i doubt it..
Old Jun 24, 2008 | 12:22 AM
robinbobin's Avatar
robinbobin
ORIGINAL: padodgeram
haha you r so right and im so wrong..i was thinkin just plain old temp sending unit...guess i should go back to 1st grade an learn to read
Old Jun 24, 2008 | 11:00 AM
WD OPN Throttle
So where is th trans temp sensor?
Old Jun 24, 2008 | 11:10 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Mounted to a tube left side above trany pan.
Old Jun 24, 2008 | 11:11 AM
WD OPN Throttle
Left side as in driver side? or passenger side?
