headlight help
Old Jun 25, 2008 | 08:40 PM
Miggy #23's Avatar
Miggy #23
Default headlight help
I have a 97 dodge ram 5.9L. My headlights recently went out but my parking and fog lights still work. I also have the ABS and Brake are lite up on the dash. I need help figuring out whats wrong. thanks for any help given.
Old Jun 25, 2008 | 09:48 PM
Gene563's Avatar
Gene563
Default RE: headlight help
Did the ABS/brake lights act up at the same time as the headlights?
My headlights will not come onoccasionally. I hit the headlight flasher level( the highbeam/turn signalswitch, pulled towards you ) a couple times and they come right on. I believe the switch contacts get dirty and this clears it...until the next time.
I hope this works for you; I can't help you with the ABS though. Good luck.
Old Jun 25, 2008 | 09:50 PM
Miggy #23's Avatar
Miggy #23
did this at the same time
Old Jul 9, 2008 | 04:23 AM
iwhitne's Avatar
iwhitne
dumb question but did you check the bulb?... I have the same issue on my truck and i kept blowing blubs due to water in my crappy stock head lights... so i ordered new ones and have not had a problem since!
