valve cover bolts help
Old Jun 28, 2008 | 03:28 PM
Mjsracer18's Avatar
Mjsracer18
Default valve cover bolts help
Hey everyone,i just got my rebuilt motor together except the freakin valve covers. The reason why there not on yet is because i dont know where the bolts go some have studs and some dont i was wondering if anyone had a diagram or any pics of the bolts so i can finally finish my motor and get it in.Its a 97 1500 with a 360 in it.
Thanks,
Matt.
Old Jun 28, 2008 | 04:05 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: valve cover bolts help
98 Ram 5.2 you mileage may vary. pass. side s___ s___b___s___s Front of truck >
s___b___s___b___s
the studs are only for the plastic clips for wire harness and sparkplug holders
Old Jun 28, 2008 | 04:10 PM
zman17's Avatar
zman17
driver side < front of truck b___s___b___s___s
b___s___s___b____s
Do not tighten them all the way until you run the plug wires and harness
Old Jun 28, 2008 | 04:51 PM
engineblock's Avatar
engineblock
they dont really matter because you are still going to close the valve covers, i perferably put the bolts in the back of the engine due to when you have the engine in they will be alittle hard to get
Old Jun 28, 2008 | 05:04 PM
zman17's Avatar
zman17
They don't all matter and some are not even used, but if he is using the factory harness' and plug wire clips they will want to be in the right position. But that is why I said don't tighten them yet.
