bypassing a/c (belt)
Old Jun 30, 2008 | 01:58 PM
8t5gt's Avatar
8t5gt
Default bypassing a/c (belt)
ne one have a part number preferably from napa for a belt to by pass my a/c. 95 1500 5.2. ? or am i just going to have to keep guessing it from the store?
Old Jun 30, 2008 | 02:04 PM
engineblock's Avatar
engineblock
Default RE: bypassing a/c (belt)
guessing... i also need a smaller belt but for bypassing the a/c and p/s
Old Jun 30, 2008 | 02:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
95 wo/ac but w/ps K070885 . This is factory wo/ac. So brackets and pulleys , etc.... may be different . So you might have to guess. Take a string and route it around the pulleys in the correct configuration and then measure it.
Old Jul 1, 2008 | 04:09 PM
8t5gt's Avatar
8t5gt
ORIGINAL: zman17
lmao i did that with my stang and still it never worked :P. ok bro i will just have to do it the hard way. i got to know everyone at napa when i did the belt on my stang, musta went in ten times.
Old Jul 3, 2008 | 06:44 AM
toader222's Avatar
toader222
thats the best idea, i had installed a set of under drives on my truck and when it came to install the belt it didnt fit so i had to go smaller, well everyone in the parts store looked at me like i was nuts when i told them thati needed a belt 2 inches shorter than my stock belt. it ended up being twice the price and at the worst parts store in town!i also found during these many trips to the parts stores that there were 2 diffrent a/c options, factory air and dealer air both of which take a diffrent sized belt.. just some food for thought.
Old Jul 3, 2008 | 08:47 AM
greenmachine's Avatar
greenmachine
Ran into the same problem with my ProCharger install. There is two options for stock belt size depending on configuration. The string deal works the best. Did you try calling the parts store and asking w/out a/c? You can also take the existing belt and route it w/out the a/c. Mark the belt at each end of the excess and take measurement. If your belt is a 506**** or a 507**** subract the measuredexcess from the three numbers after the 506 or 507. Same if your belt is a K06**** or K07****. Hope I did not confuse.
Old Jul 3, 2008 | 11:28 AM
globalwarmer01's Avatar
globalwarmer01
I would not suggest bypassing the a/c unless it is a straight race truck. You will have problems down the road with over heating. Your engine is gonna be looking for that extra stress on the motor to cool it a little. If i were you i would get a smog pump eliminator kit. That will make a difference.
Old Jul 3, 2008 | 12:26 PM
zman17's Avatar
zman17
If you don't mind me asking, why are you wanting to bypass it? If it is working now you might not want to do that! Because even when it is off and you are using heat ( like defrost especially) it will cycle to eliminate moisture and also to keep the seals and bearings lubed up.
