HELP ME CANT FIND THE PROBLEM
Old Jul 4, 2008 | 12:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: HELP ME CANT FIND THE PROBLEM
https://dodgeforum.com/m_1040882/tm.htm
Old Jul 4, 2008 | 07:26 PM
crazyval's Avatar
crazyval
ok thanks ill try to adjust the toe and see if the wheel will kind of go back in thanks a lot for your responses
Old Jul 4, 2008 | 08:37 PM
thewrench's Avatar
thewrench
post some pics...
Old Jul 4, 2008 | 11:37 PM
crazyval's Avatar
crazyval
here are some pics, first pic is the passenger wheel which comes out more and the second pic is the driver wheel which is pretty normal i think, let me know what you think
[IMG]local://upfiles/92360/395FCE3209A4457FB5E917E53DE4A778.jpg[/IMG]
[IMG]local://upfiles/92360/9DB1CCAD3C474708A1353EDF11B34FC2.jpg[/IMG]
Old Jul 5, 2008 | 12:42 AM
rabbler's Avatar
rabbler
Does your truck have any type of suspension lift?
With this style of front suspension the tracbar shifts the front wheels from side to side as the suspension relaxes and then compresses.
It's annoying but normal on these trucks for the front wheels to be slightly off to one side or the other. The only 'fix' is to install an aftermarket adjustable trac bar.
Old Jul 5, 2008 | 10:36 AM
crazyval's Avatar
crazyval
no stock factory suspention and i just changed the trac bar and all the tie rod ends everything is new but the its still shifted over, so the only thing i can do is to buy an aftermarket adjustable track bar?? or there is something else i can do??
Old Jul 5, 2008 | 12:41 PM
crazyval's Avatar
crazyval
no its completely stock suspention, is there anything else i can do to fix the problem except get a adjustable trac bar?
Old Jul 5, 2008 | 10:56 PM
rabbler's Avatar
rabbler
Not that I know of.
Replacing the front springs should shift the wheels closer to the Left but as they sag they will shift back to the Right.
An adjustable trac bar is the best solution.
Old Jul 5, 2008 | 11:26 PM
Shawn86's Avatar
Shawn86
Are you the original owner of the truck or did you just buy it?
Old Jul 6, 2008 | 12:10 AM
crazyval's Avatar
crazyval
no im not the original owner ive had the truck for a while but never really paid attention to the wheels, any web sites i can find an adjustable trac bar?
