sythetic and coventional oil
Old Jul 6, 2008 | 01:13 PM
lastrights's Avatar
lastrights
Default sythetic and coventional oil
i was wondering , i run mobil 1 convetional in my truck , is it too late or will it hurt too swith to synthetic, and would it do anything for my truck to switch , it now has 126xxx miles on it
Old Jul 6, 2008 | 05:11 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: sythetic and coventional oil
It might hurt, it might not. Synthetic is more consistent in its overall weight/thickness, so if you have any leaks filled up with sludge from conventional oil, it might clear those out and you'll leak.
Then again, it might do nothing but good. It has been proven to give you a tad more HP and a tad more MPG. It also cools the engine better.
It'll definitely be more expensive though.
Old Jul 7, 2008 | 08:50 AM
lastrights's Avatar
lastrights
when i change over , i just dont want my engine to sludge. with the milage i have on the motor i need more conditioners. and maybe it will run better in it. i dunno i just here synthetic is better for the motor. i just heard if you you mix conventional and sythetic it will sludge, just want to here your guys opionion , casue i dunno
Old Jul 7, 2008 | 09:03 AM
charlie1935's Avatar
charlie1935
[quote]ORIGINAL: lastrights
[/quote
All Mobil 1 is synthetic. It will not sludge from be mixed with regular oil.[sm=americanasmiley.gif]
Old Jul 7, 2008 | 02:04 PM
lastrights's Avatar
lastrights
http://www.synthetic-motor-oil-chang...-1-results.php
Old Jul 7, 2008 | 02:37 PM
Mowhawk's Avatar
Mowhawk
I run full syth. and i love it. When i switched over i didnt have any problems. No leaks (at the time). Now my main front and rear seals are leaking!!. Big problem. But has nothing to do with the oil. just wear and tear. If you want you can add engine restore to your oil. It helps with leaks, performance and engine life. I put it in all the time, except for once and now i have those leaks heh. But no switching you should be fine, my truck does run a lil cooler with syth.
Old Jul 7, 2008 | 09:44 PM
lastrights's Avatar
lastrights
thanks man , i do use engine restore already , and love it the 1st day i put it in at 122xxx miles , but today i drove too walmart and pep boys to buy amizol sythetic and neither carried it so i bought mobil 1 sythetic 10w30 was wondering where you got that sweet azz hood, is that a glue on or a whole hood ,
Old Jul 8, 2008 | 01:00 AM
jasonw's Avatar
jasonw
Site Moderator
He has the whole hood. He spent the bucks and did it right. [sm=smiley20.gif]
The "glue on" or tape on hoods look really cheezy to me. I laugh every time I see them, especially the ones where people don't paint them the same color as their vehicle, and they look even worse.
Old Jul 8, 2008 | 02:01 AM
Cereal Killer's Avatar
Cereal Killer
You have to buy amsoil from a vendor or off the internet.
