Front Axle Breather?
Old Jul 12, 2008 | 08:52 AM
98DodgeRam1500's Avatar
98DodgeRam1500
Default Front Axle Breather?
Anyone know where it is?
I heard that axle leaks can be atributed to a clogged breather.
Old Jul 12, 2008 | 09:13 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Front Axle Breather?
Mine comes up from the axle, and is clipped to the inside of the passenger side fender.
Old Jul 12, 2008 | 10:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
And there is a check valve on the end of it.
Old Jul 12, 2008 | 10:56 AM
98DodgeRam1500
thanks, going to go check...
Old Jul 12, 2008 | 11:38 AM
98DodgeRam1500
the check valve on the end seems like something is missing.
the cap is loose and wiggles/wobbles. thought they were spring loaded?
Old Jul 12, 2008 | 12:32 PM
Silver_Dodge
I think that's how it is supposed to be. I recall that sounds like what mine is like.
Old Jul 12, 2008 | 12:49 PM
zman17's Avatar
zman17
What S_D said. Thats normal, if you really want to make sure the hose and/or the valve is working. Disconnect the hose from the CAD and blow through it.
Old Jul 12, 2008 | 09:55 PM
TheForce55555's Avatar
TheForce55555
If the breather was plugged up, it would definitely cause the excess pressure in the axle housing to come out of the seals, I have seen a diesel engine that the breather tube was plugged and it would not run, we figured that out after a complete engine overhaul and the damn thing still wouldnt run
Old Oct 20, 2008 | 08:56 PM
98DodgeRam1500
I had to commute 75 miles today for citrix training, and during lunch break I moved my truck out of the direct sun to a shady spot. When i was walking back to the class i saw a tire print of oil. Of course it came from my truck, the front driverside axle seal. this was the most oil I have ever seen it leak. I'd say almost an ounce. most times it just leaves small drops of oil, this time a mini puddle.
I guess its time for me to attemp replacing it.
I will search this forum and others for a parts/tool list and torque specs for all the bolts I will have to remove, as well as a good oil to fill the pumpkin.
ugh.
