Front end clicking
Old Jul 13, 2008 | 09:08 PM
PurplDodge's Avatar
PurplDodge
Default RE: Front end clicking
i had this same problem with Purpl. when i toolk off the wheel i found out that the brake dust sheild was rubbing against the rotor. with some persusuasion on the dust sheild it didnt click anymore. also i have slotted rotos
Old Jul 14, 2008 | 09:35 PM
98DodgeRam1500's Avatar
98DodgeRam1500
Found my clicking source.
Passenger side u-joint. I just reached in there and grabbed the axle and twisted it, and there was a fair amount of play in th u-joint.
So... time to do a forum search on the best way to replace it. hoping i can do it without pulling the bearing out.
Old Jul 14, 2008 | 09:49 PM
98DodgeRam1500
ORIGINAL: lupenbeast
Hi all, new to the forum, MOPAR for LIFE! Have a clicking sound from front left side, not sure exactly where. Clicking stays in time with speed, going slow...slow click, etc. Doesnt happen while turning, just straight line. Any thoughts?
check this link out.
https://dodgeforum.com/postnumber.asp?id=1339983
Old Jul 14, 2008 | 09:56 PM
PurplDodge's Avatar
PurplDodge
when you do replace it get some precision u-joints that are greaseable 'cause they'll last longer
Old Jul 14, 2008 | 10:06 PM
98DodgeRam1500
ORIGINAL: PURPLDODGERAMITMFERS
right, but can i replace it without removing the axle shaft, bearing, or CAD?
Is there a write up on replacing the passenger side one? I did a forum search here, but found nothing
Old Jul 15, 2008 | 04:45 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You will need to remove the axle.
