biggest tire to fit stock area
Old Jul 14, 2008 | 02:05 PM
onceaday's Avatar
onceaday
Default biggest tire to fit stock area
what is the biggest tire i can fit in a stock wheel housing? i have285/75/r16 right now, but i would like to see of 33" tires would fit or if i have to stay down towards a 31". I have a 2000 dodge ram 2500HD with the plow package/towing package. anybody have any clue as to what size and what tire tread pattern i should use? its a daily driver in a heavy snow area in michigan's upper penninsula. let me know if you have any ideas.
Old Jul 14, 2008 | 02:20 PM
sunngod's Avatar
sunngod
Junior Member
Default RE: biggest tire to fit stock area
I had 315/75 16s on my 98 2500 4x4 when I got it. I have since switched to 33 12.50 16.5s with after market wheels. They rub a little on the plastic when turned all the way and I hit a bump. If I had the stock wheels wil more backspacing it wouldn't rub at all. Your 285s are almost 33s.
Old Jul 14, 2008 | 08:10 PM
dsertdog56's Avatar
dsertdog56
A 285 is technically a 33 inch tire. You might be able to get a "small" 315 in there, and for sure with a 2 inch spacer.
Old Jul 14, 2008 | 09:24 PM
mstephen89's Avatar
mstephen89
33's, but like said, I would get a little spacer, to just help it. Can't beat it for less then 100 bucks
Old Jul 14, 2008 | 10:10 PM
Cereal Killer's Avatar
Cereal Killer
33s fit stock on a 1500. A 2500 sits about 2 inches higher than a 1500. So 33x12.5s will fit just fine.
Old Jul 14, 2008 | 10:40 PM
dodge@1997's Avatar
dodge@1997
I have 305/70r16's on mine that is 33x12.5 1997 2500
Old Jan 21, 2009 | 06:55 PM
cs006672's Avatar
cs006672
hey can someone help me, I have a 99 dodge ram 1500 4x4 and i want to put some bigger tires on it. Whats the biggest tire i can go with with out rubbing? I'd like new wheels too, any suggestions?....
Old Jan 21, 2009 | 08:41 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Old Jan 21, 2009 | 09:11 PM
gipperkid's Avatar
gipperkid
And that is maxing out the gear, assuming your truck has 3.55.
Old Jan 21, 2009 | 09:25 PM
vmann's Avatar
vmann
im running 285/75/16's on my truck with 3.55 gears right now and its running fine.. only rubs when i lock the wheel
