Old Aug 6, 2015, 02:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
How to install distributor
Old May 28, 2012 | 09:05 AM
Originally Posted by Montalto633
I know this might sound crazy but if my distrubutor isent on mark one can I just make where it's pointing my number one as long as I move all the wires to that set up or so I have to take the motor out of the truck to fix it ?
Actually.... no. You can't. Doing so would throw the cam position sensor way off..... which would in turn throw injector timing way off. Resetting fuel sync would be truly interesting in such a scenario.......
Old May 28, 2012 | 09:42 AM
Montalto633's Avatar
Montalto633
Unhappy
The truck cranks over but did not start. So the Dakotas have to have the fuel done also? With the scanner
Old May 28, 2012 | 10:09 AM
Yep, same engine/electronics.
Old Apr 7, 2015 | 04:11 PM
95 dakota fan's Avatar
95 dakota fan
Originally Posted by master tech
Its the same.You are either number 1 or number 6. If you try to start the engine and it doesn't, move to number 6. But you can move the oil pump drive gear too.
how do you move the oil pump drive so it is pointing at number 1 on intake manifold
Old Apr 7, 2015 | 04:17 PM
95 dakota fan
how do you adjust the timing of the oil pump so his face and number one on the engine intake manifold
Old Apr 8, 2015 | 07:44 AM
1997JollyGreenGiant's Avatar
1997JollyGreenGiant
I would use a large, flathead screwdriver.
Old May 8, 2015 | 11:45 AM
98Ram360jr's Avatar
98Ram360jr
im having a slight problem with my truck. plug wires are sorta swapped. 1 and 2 are swapped around and i think so are 5 and 6..... would that mean that the distributor was turned 180 i have two plugs so far i can tell not firing. put new plugs in and just after a few turn overs 6 are black tipped and 2 still not firing. anyone have any ideas or suggestions. would be appreciated.
Old May 8, 2015 | 12:57 PM
Make sure your firing order is correct first.
Old May 8, 2015 | 09:26 PM
98Ram360jr's Avatar
98Ram360jr
TDC the rotor button is pointing to cyl 8
Old May 8, 2015 | 10:05 PM
Need to fix that first. Otherwise, fuel sync is going to be WAY off.
