Old Aug 6, 2015, 02:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Electrical System
Print Wikipost
How to install distributor
Old May 8, 2015 | 10:55 PM
  #21
2damnyankee's Avatar
2damnyankee
Originally Posted by 98Ram360jr
TDC the rotor button is pointing to cyl 8
Are you on top dead center compression stroke ? that is the only way for top dead center.
the best way to get oil drive lined up is use a large screw driver and turn drive shaft, Or you can remove the pan and oil pump then install distributer pointing to #1 on the cap then install oil pump and pan. There is a bright side to removing oil pan you can clean all the sludge out it clean it up and paint it plus do a oil change.
