Transmission check valve, NOW NEED HELP
Old Aug 3, 2008 | 05:05 PM
theviper90210's Avatar
theviper90210
Default RE: Transmission check valve
Thanks for the ideas I will prob take the lines off the cooler and blow it out. What else do you guys think
Old Aug 4, 2008 | 02:17 PM
theviper90210
any other suggestions guys?
Old Aug 4, 2008 | 02:55 PM
aim4squirrels's Avatar
aim4squirrels
clutch material and metallic debris will clog the check valve. Replace the tranny filter, clean the magnet, blow out the check valve with compressed air.
Old Aug 4, 2008 | 10:20 PM
99blueram's Avatar
99blueram
Viper, I just rebuilt my trans myself and just used a drill bit to remove check ball. I learned that the factory trans does not pump in park, so that will lead to a sluggish start when shifted into gear. I added a jr kit to my valve body to allow it to pump in all positions. I have had no problems yet. Hope this sheds alittle on your problem.
Old Aug 7, 2008 | 08:23 PM
theviper90210
thanks guys anymore advice on the issue, hope to work on it this weekend
Old Aug 8, 2008 | 08:55 AM
dsertdog56's Avatar
dsertdog56
I removed the factory check valve and cooler years ago and replaced the cooler with a HD unit from the aftermarket. Both OEM pieces are prone to plugging.
I also fabbed some brackets to put the cooler in front of the A/c evaporator. You don't have to do that, but I think it helps.
Old Aug 8, 2008 | 10:18 AM
hometheaterman's Avatar
hometheaterman
Yup when I had my APS tranmsission installed I had a B&M transmission cooler put on without the check valve.
