Using oil
Old Jul 31, 2008 | 01:56 AM
Sehr916's Avatar
Sehr916
Default RE: Using oil
No leaks or smoke either...
Old Jul 31, 2008 | 01:58 AM
Sehr916's Avatar
Sehr916
I'm thinking that maybe at higher rpm's
Old Jul 31, 2008 | 02:00 AM
Sehr916's Avatar
Sehr916
the motor leaks
Old Jul 31, 2008 | 07:23 AM
98DodgeRam1500's Avatar
98DodgeRam1500
Cracked heads?
Old Jul 31, 2008 | 09:47 AM
aim4squirrels's Avatar
aim4squirrels
could be,
rear main seal - check for leaks around tranny dust cover
oil pan gasket - check round perimeter of oil pan
front main seal or timing cover - check around timing cover, hard to see with accessory bracket on.
Old Jul 31, 2008 | 09:52 AM
aim4squirrels
valve cover gasket leak - look for oil dripping down engine to manifolds
Old Jul 31, 2008 | 09:53 AM
aim4squirrels
plenum gasket - see above
cracked head - do compression test followed by a leak down test to verify.
Old Jul 31, 2008 | 09:55 AM
aim4squirrels
bad head gasket, or rings - burning oil like a banshee.
Old Jul 31, 2008 | 11:27 PM
Visious 318's Avatar
Visious 318
I picked up everything to do the intake pan gasket today I hope this fixes it. Too bad i have to reuse the tin plate and don't have the green to get the fix it plate.
[align=left] [/align]
Old Aug 3, 2008 | 12:49 PM
Visious 318
Compression checked out but the plentum gaskit is blowed out i have oil in the intake. I am looking for another intake to mod befor this weekend so all i have to do is swap it out.
