Using oil
Old Jul 30, 2008 | 09:49 PM
Visious 318's Avatar
Visious 318
Default Using oil
I have a 318 with 152,000 miles on it that uses oil internentintly. I go thrue a qt. every 450miles but never see any blue smoke driveing and it has no leaks.[align=left] [/align]
Old Jul 30, 2008 | 09:53 PM
dodgeram07's Avatar
dodgeram07
Default RE: Using oil
plenum?? maybe.. what do you guys think?
Old Jul 30, 2008 | 09:54 PM
Visious 318
Every ONCE and a while when you go to start it it will smoke like a banche for 30 sec.
Old Jul 30, 2008 | 09:56 PM
Visious 318
then quite and won't do it agine for a week or two or it my do it the next time it starts.
Old Jul 30, 2008 | 09:57 PM
98DodgeRam1500's Avatar
98DodgeRam1500
1998 5.9L with 110K, I might go through 1QT in 3500 miles. I normally change my oil at 3000, and when i do its just at or above the min line.
No leaks either, no noticeable smoke, and easy on the skinny pedal on the right.
1 QT in 450 miles is substantial, yes, thats a symptom of the plenum issue. Take off your air cleaner and open the butter flies and look down in to the intake with a flashlight, look back towards the firewall and see if you can see any oil pooled. Grime is normal, but nothing that looks wet or pooled up.
Old Jul 30, 2008 | 09:58 PM
Visious 318
Any ideas? I know the intake pan is bad about leaking on these things but this an't a little oil all the time.
Old Jul 30, 2008 | 09:59 PM
Visious 318
It don't rattle or knocksome times has a ruff idle when cold for the first min then goes away.
Old Jul 30, 2008 | 10:00 PM
Visious 318
with the plentum gaskit leaking should it use oil all the time like bad rings?
Old Jul 31, 2008 | 01:53 AM
Sehr916's Avatar
Sehr916
98Dodge: I have a similar problem on my 5.9 too.
Old Jul 31, 2008 | 01:54 AM
Sehr916's Avatar
Sehr916
I've done the plenum swap but I still go through oil every approx. 1000 miles too
