why such much more power????
Old Aug 5, 2008 | 09:21 PM
lastrights's Avatar
lastrights
Default why such much more power????
http://www.superchips.com/products.p...Grand+Cherokee
5.9 Max 46.9 HP and 59.4 ft lbs torque . and the 5.2 Max 18.7 HP and 30.2 ft lbs torque. why is the 5.9 getting so much more power than the 5.2 liter, it even get rated more power than the hemi using this programmer -5.7 Hemi Max 21.4 HP and 34.2 ft lbs torque
Old Aug 5, 2008 | 11:08 PM
98DodgeRam1500's Avatar
98DodgeRam1500
sounds a bit "too good to be true", but if it really produces that much of a gain... then tell me where to get them!
At what RPM does it give you more power?
Can anyone prove it to be true?
honestly I am looking to upgrade in the other area, braking.
Last edited by 98DodgeRam1500; Aug 5, 2008 at 11:10 PM. Reason: typo, grammar, and one more thought.
Old Aug 5, 2008 | 11:42 PM
aim4squirrels's Avatar
aim4squirrels
I would imagine that there was a very temporary spike in HP and torque at a specific RPM, and since that's the highest number, that's what they publish to sell 'em. So long as they've got the dyno results to back it, they're legal.
It's kind of like saying you can run a 4 minute mile if you just multiply your 100 yard dash time by 17.6.
Old Aug 6, 2008 | 04:02 AM
talon6's Avatar
talon6
i am thinking if you have the death flash gains could be more than normal, give it that hp and torque rating. i am going to get one soon to try out.
Old Aug 6, 2008 | 06:05 AM
lastrights's Avatar
lastrights
it shouldnnt be the number from a death flash becasue not all 5.9 360 have it!!! it just seems like a big numbers compaired to the hemi and the 5.2 ,when the 5.2 isnt that small compaired to the 5.9.
Old Aug 6, 2008 | 06:18 AM
lastrights's Avatar
lastrights
and i was wondering with superchips can you pick you tune and unplug it, and put it ack in when you want something else .... or does it always have to be in your port,
Old Aug 6, 2008 | 08:23 AM
Mowhawk's Avatar
Mowhawk
Either way the 5.9 is a bigger engine, bigger engines are more capable of producing more hp. Cant beat a bigger block. That being said, it still does seem odd that the 5.9 would get a better gain, i can understand more than the 5.2. But i dont see how its that much over the 5.7, seems to me that the 5.7 would have better tuning capabilities with a more modern engine and computer.(better tuning without swapping parts)
Old Aug 6, 2008 | 08:30 AM
aim4squirrels
perhaps the boys at DC are already milking the hemi's potential better than they the 5.9.
the Heads, TB, intake manifold, EFI system and a lot of other stuff is standard between the 5.2 and the 5.9. a larger engine has the potential for more power, obviously, but if you're "crippling" it with 5.2 parts and a tune for those parts, you aren't seeing max potential.
The heads on a hemi are clearly different than the non hemi.
Old Aug 6, 2008 | 10:37 AM
talon6's Avatar
talon6
plug it in,pick your programming,and unplug it. you donnt leave it plugged in. and yes you can change your tune if donnt like something. or take it back to stock or whatever.
maybe the one they did the testing on was death flashed. sometimes sellers are slick that way, to get those big numbers.
Old Aug 6, 2008 | 12:39 PM
PurplDodge's Avatar
PurplDodge
maybe its because the 5.9 might be more detuned than the 5.2 from the factory. much like the diesels are
