Tune Up in A Can?
Old Aug 6, 2008 | 01:34 PM
pro_onSNOW's Avatar
pro_onSNOW
Default Tune Up in A Can?
Has Anyone used this product? it says it spray it into the vacume line, where would I find that i have a cold air intake on m 5.2 l
Old Aug 6, 2008 | 06:36 PM
Visious 318's Avatar
Visious 318
It is just like NEW ENGINE IN A BOTTLE you pour it in a wola you worn out knoking engine is now not using oil or knocking. Nothing is better than doing the real thing.
Old Aug 6, 2008 | 08:19 PM
dhvaughan's Avatar
dhvaughan
the big hose from the intake to the brake booster is a vacuum line. you can dump it in there. don't expect much....
Old Aug 6, 2008 | 08:29 PM
PurplDodge's Avatar
PurplDodge
ha ha thats funny! i guess im crazy to spend 2 hours to replace my plugs, wires, cap, rotor, run engine flush, change the oil, and filter, and to clean my k&n. you guys have it easy!
Old Aug 6, 2008 | 10:08 PM
rabbler's Avatar
rabbler
It's a combustion chamber style cleaner. They do work but are no replacement for a physical tune-up.
Old Aug 6, 2008 | 10:46 PM
PurplDodge's Avatar
PurplDodge
so im not crazy? thats not what my theripast said!
Old Aug 7, 2008 | 01:33 AM
pro_onSNOW's Avatar
pro_onSNOW
Ha, I have already done most of that fun stuff, I am just looking to try and restore some power to my old engine with 160,000 k.
It is supposed to work to clean the engine internally and I am hoping it will do a effective job of cleaning the valves, since it delivers a more concentrated burst of cleaning fluid. I have used some fuel system additives, but have never noticed any improvment of any kind from using products like that.
Does changing the plug wires and cap accually affect anything? I though that was only applicable on the older style vehicles where the plug wires weren't build with as much technology and lost conductivity over time. Neway as anyone notice a improvement?
What about adding a engine oil additive like Slick 50 to try and reduce friction or drag withing the engine. Has anyone noticed any improvements while using a friction modifyer?
Thanks for your input.
Old Aug 7, 2008 | 07:29 AM
lastrights's Avatar
lastrights
i used that that engine retore in a can its oil that you add in your oil at evreychange, i swear by the stuff my motor has 126xxx and i felt more power by like the 2nd change. and othere people on here swear by it too, actually someone on here did a compression change on it , and ended up getting full compression on the motor.
Old Aug 7, 2008 | 08:57 AM
dhvaughan's Avatar
dhvaughan
cap and rotor and plugs degrade/erode, etc over time, and replacing them every 2-3-4 years will keep your spark hot and clean. plug wires do degrade over time, more from heat and age than anything else. i replace them about every 5-7 years or so. if you still have the stock wires i'd replace them one of these days.
Old Aug 7, 2008 | 02:26 PM
pro_onSNOW's Avatar
pro_onSNOW
I am thinking about switching my truck over to castrol syntec oil, would it be worth it to add a can of the engine restore to that....or would it be a waste of premium synthetic oil?
Has anyone noticed a difference between running premium synthetic (ie. castrol, mobile 1)
or cheaper sythetic oil like the Motomaster synthetic...which sells for about half the price.
