How to Replace Brakes on 01 ram
Old Jan 28, 2005 | 04:31 PM
Theo's Avatar
Theo
Default How to Replace Brakes on 01 ram
Can someone plz tell me how to replace the front brake pads on a 2001 dodge ram 1500.
A link to a guide with pictures or steps would be greatly apprecieated.
Old Jan 28, 2005 | 04:35 PM
Snafu's Avatar
Snafu
Default RE: How to Replace Brakes on 01 ram
Buy a Haynes manual. It's worth the money.
Old Jan 28, 2005 | 04:38 PM
Theo's Avatar
Theo
well what kind of tools will i need?
Old Jan 28, 2005 | 05:07 PM
Theo's Avatar
Theo
i know this is for a rear set of brakes but will this link be able to give me an idea??
http://thebansheezone.tripod.com/id57.htm
Old Jan 28, 2005 | 05:08 PM
Snafu's Avatar
Snafu
Lug wrench, 3/8" Allen wrench, flathead screwdriver, big hammer, 6" C-clamp, and possibly a cheater bar for the brake pads.
Ok, here's what you do. Jack the truck up, put it on jackstands. Take the front wheels off with the lug wrench. Take the calipers off by backing off the 3/8" Allen head bolts, might need a cheater bar for this. Pop the calipers off the rotors, might need to tap them with a big hammer. Pry the old outter pad off the caliper with a screwdriver. Pop the hood, take the top off the brake master cylinder. Put the 6" C-clamp on the caliper so you're pushing the inner pad toward the back of the caliper. Crank it down as far as it'll go. Take the inner pad off the caliper. Put the new pads on, put the cap back on the master cylinder, and reassemble.
You should also replace the rotors, or at least have them turned. They should come right off the hubs once you take the calipers off.
Old Jan 28, 2005 | 05:09 PM
Snafu's Avatar
Snafu
The principal is the same...
Old Jan 28, 2005 | 05:21 PM
wkeiter's Avatar
wkeiter
The hayne's manual I bought only had the old style single-piston removal. I had to wing it for my 01 Ram with dual-piston calipers.
Old Jan 29, 2005 | 01:03 PM
proud american's Avatar
proud american
I have a 2001 and a haines the brake in the book is not what is on this truck as far as how the pad is mounted,basic caliper removel is the same but the pads do not clip on as others they kinda slide on a track like assembly.to this the caliper need to be broken down after removel did mine last year,hard to explain but not hard to do once I got it figured out.
Old Jan 30, 2005 | 06:16 PM
bign1976's Avatar
bign1976
PUMP YOUR BRAKES BEFORE BACKING OUT OF THE GARAGE!!!!!! I almost went off the end of the driveway
