99 Ram 318 running rough??
Old Aug 10, 2008 | 11:42 PM
mrice2311's Avatar
mrice2311
Question 99 Ram 318 running rough??
My 99 Dodge 4x4 318 is running rough. It just started doing this yesterday. It hesitates during acceleration. I changed the plugs and wires today, no change. I can smell fuel after I get out after driving it: It smells like the fuel isn't burning correctly. No leaks. Any suggestions? Thnx
Old Aug 10, 2008 | 11:44 PM
dhvaughan's Avatar
dhvaughan
were any of the plugs wet or fouled ?? suggesting a leaky injector.
otherwise, i'd consider replace the front o2 sensor(s), as it/they control fuel trim. the rear o2 sensor (behind the cat) just checks that the front one is working and otherwise does little to nothing.
Old Aug 10, 2008 | 11:46 PM
mrice2311's Avatar
mrice2311
One of the plugs was wet. The rest were dry, light brown color, although well worn.
Old Aug 10, 2008 | 11:51 PM
dhvaughan's Avatar
dhvaughan
remove the new plug in the position where the old plug was wet. see if the new one is equally wet. if so - injector. they're sort of expensive. you might pick up a whole set at the junk yard cheap if funds are tight.
