New to Ram
Old Aug 17, 2008 | 12:04 AM
  #21
bronco2454's Avatar
bronco2454
Junior Member
They arent going to trade me straight for for a 09. I would be getting the 94 dodge straight across. The dodge seems to be more truck then the Ford. As I said the tranny in the ford shifts really hard and slips out of od a lot. So its more down to which I would rather spend money on. The ram runs good. The only problem is it pulls to the right a lil bit. It pulls hard throughout all gears and shifts very well though.
Old Aug 17, 2008 | 12:12 AM
  #22
Rex-TheDOGG's Avatar
Rex-TheDOGG
Originally Posted by Gord.
I certainly wouldn't say 'Very' prone to cracking, it is a problem that has come up a few times,
but there are also many people with over 200K on their original heads.
It's a problem that has come up a lot more than a few times. Talk to any service manager at any Dodge dealership and you'll get my drift. In my opinion, it is a bad head design where a sharp peak is milled into the head, right between the valve seats. The crack starts there and then migrates into one or both valve seats. Like 98DodgeRam1500, I try to tell anyone considering a Magnum powered Ram that they must check for this condition before buying. I have no axe to grind with the Dodge Ram. If I were to buy a new truck today, it would probably be a Ram. That is why I'm committed to fixing and upgrading this particular truck because I like it.
Old Aug 17, 2008 | 06:42 AM
  #23
98DodgeRam1500's Avatar
98DodgeRam1500
Sounds like you are going to do it since your ford is starting to need maint/repairs that are pricey too.
Also, you might want the change in scenery.
Go for it... but that Dodge Ram the only thing out there?
The owner is willing to trade you even for you F-150, does he know the mechanical condition of your truck?
Old Aug 17, 2008 | 07:16 AM
  #24
98DodgeRam1500
Originally Posted by jason.w
You have to keep in kind that 98DodgeRam1500 is our resident Dodge hater. He ran into a lot of problems with his truck, sees a few others on here with similar issues, and has labeled the entire Dodge/Chrysler brand as bad.
Not true... I also own a Pacifica and love it. (its the wife's).
The IAC (I believe you meant instead of ICA) and TPS are exposed electronic parts (sensors) in a dirty, hot enviroment, especially with a bad plenum. Of course they will go bad eventually.
Nope, I meant the IAC. ICA is the Internet Connection Agent that Citrix uses for their Presentation Servers (now called XenApp) you can download the client here. http://www.citrix.com/English/SS/dow...&productId=186. The IAC is the Intake Air Control that causes the trucks to idle rough or stall when dirty or defective. Read here how to clean your IAC selenoid, http://www.v8performance.com/tipsandtricks.htm#CleanIAC
Old Aug 17, 2008 | 10:06 AM
  #25
bronco2454's Avatar
bronco2454
Junior Member
I am trading a used car dealer for it. He took the f150 and drove it around his lot I doubt it left first that was his idea of a test drive. The Ram is the only thing that isnt going to cos me anything. I paid 300 bucks for the f150 back in May. So at the end of the day I guess I could afford without being to hurt to have to pay 500-1000 into the Ram on repairs if need be and still come out with a pretty cheap truck. I think he might be more interested in my truck for parts. He has a really nice one like mine that he says needs motor work. My motor runs excellant.
Old Aug 17, 2008 | 10:10 AM
  #26
bronco2454's Avatar
bronco2454
Junior Member
Anyone got an idea on why it might pull to the right though. It is not a major pull but you can tell none the less.
Old Aug 17, 2008 | 11:20 AM
  #27
98DodgeRam1500
alignment, or bad tie rod ends,brakes, bearings, maybe trac-bar (doesn't sound like a trac-bar symptom). it could be many things, or just one thing. have the dealer fix it before you take it off the lot.
Keep us up-to-date on how the truck is after you get it, a pic would also be nice.
best of luck in your RAM purchase.
Last edited by 98DodgeRam1500; Aug 17, 2008 at 11:33 AM. Reason: added more blah blahs.
