how to get serious hp out of my ram
Old Aug 19, 2008 | 04:20 PM
96dodgeramsport's Avatar
96dodgeramsport
Question how to get serious hp out of my ram
i have a a 1996 dodge ram sport and it is 100% stock...so i wanted to know how i can get some real power out of it....300hp and up.... but without using turbo/super chargers
Old Aug 19, 2008 | 04:36 PM
Jr. Mechanic's Avatar
Jr. Mechanic
If money isnt an issue, I would start with the basics, exhaust, an open element air cleaner, a tranny cooler and shift kit, and a good tune up. Then I would do a cam, a double roller timing set, and a fastman TB. That should get you well over 300 HP depending on the cam you get.
Old Aug 19, 2008 | 06:01 PM
96dodgeramsport
so what cam should i buy
Old Aug 19, 2008 | 06:23 PM
Jr. Mechanic
Personally I would contact Comp Cams or another company of your choice. Give them your vehicle specs, and your needs and they can recommend a catalog cam or custom grind one for you.
Old Aug 19, 2008 | 07:10 PM
96dodgeramsport
will all of this improve or decrease my mpg...... thanks
Last edited by 96dodgeramsport; Aug 19, 2008 at 07:12 PM. Reason: forgot something
Old Aug 19, 2008 | 07:46 PM
Jr. Mechanic
Everything except the cam may increase the fuel mileage slightly, but not much. The cam will decrease it anywhere from 2-5 mpg (depending on how big of cam you get.) Power and fuel mileage are not two things that generally come together, you have to pick one.
Old Aug 19, 2008 | 08:41 PM
padodgeram's Avatar
padodgeram
Few things left out .. bore .30 over , stroker kit , dont forget heads , valves , roller rockers .. then with a cam you gotta be careful that it does not throw the PCM into a fit...
Old Aug 19, 2008 | 11:04 PM
96dodgeramsport
almost forgot....should i do this http://i151.photobucket.com/albums/s...704148_131.jpg
Old Aug 20, 2008 | 02:31 AM
jasonw's Avatar
jasonw
Site Moderator
Ram air. Sure, especially if you have the fog light holes but not fog lights in them. That would be one step up from the open element air cleaner that Jr. Mechanic described.
Old Aug 20, 2008 | 09:30 AM
IndyRamMan's Avatar
IndyRamMan
I estimate my truck to be about 300-310 horse and 340-370 tq. Before the cam I averaged 10.1mpg, after the cam I averaged 10.15 mpg. So that should answer the mileage question.
