i know the the heavy duty service comes with alot of useful features, i just recently went to the dealership to get a spec cheet of my 00 dodge ram 4x4 sport to be suprise that i have alot than what i had exspected. i have the the heavy duty service group but not the off road package.
my question is what is the unique suspension? i know its the trussed dana 44, on my bluid sheet is says DANA M44/216MM. im wondering if those are two different front ends. also on the spec sheet it had the anti slip on there too. what exactly is in the front of an stock off road package, ive notice that they sit taller in the front then a non off road truck. is it a different shock? or a spacer? or is it just naturaly that high? can some one help me out on what the special skid plate is? how it different from the heavy duty group? sry for all the questions im new to all this
Service Group --- Heavy Duty, includes 136-amp alternator, 750 amp battery, auxiliary automatic transmission oil cooler (not available with 3.9L V6 or manual transmission), transfer case skid plate (4x4 models only) and heavy duty engine cooling (Standard on 2500 and 3500 Chassis Cab models)
and the off road group had
Off-Road Group
--- Includes the Heavy-Duty Service Group, limited-slip rear differential, unique suspension, special skid plates, tow hooks, 4.10 axle ratio, fog lamps, special graphics, off-road tires, and 17" cast aluminum wheels
The Offroad editions sit higher because they have different coil springs up front. They also have larger but not longer shocks but shocks do nothing for the ride height of the vehicle. I think they also have an extra leaf in the rear but I'm not positive on that.
As for the trussed D44 do you know what trussing is? I will see if I can find a picture for you. Just because you have the D44 doesn't mean you have it as all trucks came with the D44. I doubt you have it but I will see if I can find pictures to show you so you can check.
The front axle in the offroad edition is just a open differential and the rear has a limited slip. A crappy one I must add. Sounds likes you have that too.
Not sure on the special skid plate. I have the Offroad edition but not sure which skid plates the regular model does and doesn't have so I don't know which extra ones I have.
Kind of hard to tell in that photo as I can't remember exactly what mine looks like but comparing it the one above it looks like you have the non offroad model one. Also does your rear axle have a tag on it somewhere telling you the gear ratio? The Offroad editions will have 4.10 gears.
Do you have the tow hooks? I'm guessing you don't have the offroad package since your build sheet doesn't say so but who knows.
I don't remember the sites that tell you what the offroad package includes and I'm not sure if I remember everything or not.
Basically it's got a 1.5" or so of additional height over the stock one, tow hooks, additional skid plates, trussed front axle, lsd in rear, 4.10 gears, larger not longer shocks, transmission cooler(I'm assuming this is the hd service group), 17" wheels, and additional badging. Basically what you posted above that it has.
i dont have the off road package, i know that. i have the 3.55 gear ratio that was in the bulid sheet. i have the hd service group, just not the off road package. i was just is your spec sheet suppose to be prvite? or can you share it?
I have no idea. I don't see why you couldn't share it but I honestly have no idea. So what are you wondering then? If you don 't have the offroad package are you wondering what you can add to make it like one or what? I'm confused as to what you are trying to do.
i just wonderin on how close my truck was to one thats all. i figured out i can add spacers in the front to raise it to level it out right? i just wanted to compare my spec sheet to somebodys elses that had the off road package thats all. thanks for you help i apprecate it!
I’m actually quite curious about mine, mine is a 2001 ram 1500 with a 5.2 v8 and 5 speed manual, with the heavy duty service package and off road package
