help needed
Old Aug 30, 2008 | 11:46 PM
MDDODGE's Avatar
MDDODGE
Default help needed
I got a 1999 dodge ram 4x4, 5.9l(gas), automatic. i got the codes P0505 and P0306. With the code P0505 i replaced the Iac motor and the code still pops up. As for the P0306 i swaped sparkplugs, cap and rotor. It still pops up. The MIL light been on for awhile. Any suggustions?
Old Aug 30, 2008 | 11:59 PM
Trey318's Avatar
Trey318
http://www.obd-codes.com/p0306
http://www.jeepforum.com/forum/showthread.php?t=219895
Hope those help.
Old Aug 31, 2008 | 12:06 AM
Visious 318's Avatar
Visious 318
What compression does #6 cylander (dry and wet test) have and are you sure #6 is geting fuel from the injector? This info. will let one know if you have a bumb injector or a cylander with a bad valve, piston, lobes worn off cam, ect
Old Aug 31, 2008 | 12:11 AM
MDDODGE's Avatar
MDDODGE
its dark here. will i hope its not bad to where i have to tear the motor apart.
