How
Old Sep 2, 2008 | 02:42 PM
tomcat_m's Avatar
tomcat_m
Default How
How do you get the hooks off....I want to put a cover on it
Tryed screws will not move even with a impact driver
Old Sep 2, 2008 | 03:53 PM
hometheaterman's Avatar
hometheaterman
I'm guessing they are screwed in but I don't know for sure. Are they screws or torx heads? If an impact driver wont work maybe try heating them up a little then try the impact driver.
Old Sep 2, 2008 | 04:32 PM
tomcat_m's Avatar
tomcat_m
This is from a 98 ram....no body had trouble getting this off to put a bed cover on
Yes they are screw it...see pic...the problem is the case is plastic so you can't heat them
Mike
Old Sep 2, 2008 | 05:19 PM
Trey318's Avatar
Trey318
Take your Philips head to the screw, and try hitting on the handle end of the screwdriver one or two times with a hammer. Then get in the bed, put as much downward force you can put on the screwdriver and turn it. Idk what to tell you if that doesn't do it, other than breaking it off.
Old Sep 2, 2008 | 05:23 PM
Rex-TheDOGG's Avatar
Rex-TheDOGG
Go get some PB!
Old Sep 2, 2008 | 06:19 PM
BlueBeast2's Avatar
BlueBeast2
drill them out?
Old Sep 2, 2008 | 06:41 PM
hometheaterman
Yup I'd say maybe some PB blaster and keep going at it with the impact screwdriver.
Old Sep 2, 2008 | 07:50 PM
95laRAMie's Avatar
95laRAMie
is there perhaps a nut holdin the screw in, that may be reachable from under the bed rail. try removing the bed liner and look for a nut
Old Sep 2, 2008 | 08:24 PM
98DodgeRam1500's Avatar
98DodgeRam1500
I used to have those in my 95 F-150, they were great!
I am trying to recall how they anchored in...
I found a site that has a exploded diagram.
http://www.tonnocover.com/highland_b...medium=Website
Old Sep 2, 2008 | 09:10 PM
dhvaughan's Avatar
dhvaughan
just drill them out. maybe drill a pilot hole and try an ease-out. if that fails just keep drilling.
