dash finally fixed
Old Sep 4, 2008 | 06:54 PM
aim4squirrels's Avatar
aim4squirrels
But not until after I've gotten my dash fixed.
Old Sep 4, 2008 | 09:36 PM
Trey318's Avatar
Trey318
If this is really true, itd be nice to get a refund for some of the $300 I spent on a new top..
Good find tho if this is real.
Old Sep 4, 2008 | 09:46 PM
hometheaterman's Avatar
hometheaterman
Exactly. I want a refund. I also am having my newer one crack around one bolt hole. I put superglue on it and you can't really see it. I noticed it's also cracked one other place behind the black bezel where it snaps in. Piece of crap dashes. I already replaced this thing once almost 2 years ago. That's not that old.
Old Sep 4, 2008 | 09:51 PM
Trey318's Avatar
Trey318
I hope mine doesnt start doing that any time soon. I'm babying mine atm, with the windshield cover. I figure that might help a little bit. I also didn't put too much torque on most of the bolts. But itd be nice to get around $200 back and maybe even throw in that warranty..
Old Sep 5, 2008 | 06:29 AM
HankL's Avatar
HankL
I wonder if an adhesive sound deadener sheet
applied to the underside of the dash,
like the DynaMat or cheaper BrownBread
would strengthen the dash enough to prevent some cracks?
http://www.b-quiet.com/brownbread.html
http://www.edesignaudio.com/index.php?cPath=1_24
http://www.dynamat.com/
Old Sep 5, 2008 | 11:06 PM
TonkaMan's Avatar
TonkaMan
thats a really interesting idea I would think the adhesive would even hold the dash together if it did crack instead of having pieces falling through.
Old Sep 10, 2008 | 03:05 PM
TonkaMan's Avatar
TonkaMan
just curious to see if anyone has tried this route for their dash. wondering if anyone else would have the same luck or if mike was just in a stellar mood that day
Old Sep 10, 2008 | 04:21 PM
rockarmymedic's Avatar
rockarmymedic
Default Just tried it
I just tried it and was told rather rudely that as my warranty had expired that tough luck. I then responded that I guess this is one of the reasons why Dodge stock is in the tank and that they will all be unemployed very shortly.
Old Sep 11, 2008 | 12:06 AM
offroadzj's Avatar
offroadzj
i actually just spend about 3 hours today removing my dash top. I ended up jsut loosening the bolts (2 on each side, then the 2 steering wheel bolts) to tip the dash forward and got the screws that face upwards with a stubby screwdriver. From here I am going to repair my multiple cracks, then fiberglass the entire cover. Im thinking of adding a 3 gauge pod for 2" gauges (trans temp, and then 2 others... probably digital voltage and something else). I'll make sure to post up a topic and keep it updated as I go. Hopefully with the fiberglass on top, it should eliminate future cracking.
Old Sep 11, 2008 | 11:41 PM
eaglestorm's Avatar
eaglestorm
I was wondering if you called the dealer a thief (stealership) because you had to pay 100 deductable ? the way you talk there just there to steal your money
