Fuel pressure prior to starting? 1999 5.2L
When you turn on the key, should you have 49psi from the schrader valve on the fuel rail or only after starting?
Also, does anyone know a cheaper way to measure the fuel pressure (rig a fitting to fit the valve on the fuel rail) other than a $40 gauge from Autozone?
Thanks,
Frank
Thanks,
Frank
