problems with transfer case
Old Sep 10, 2008 | 08:42 PM
99DRAM31887's Avatar
99DRAM31887
Default problems with transfer case
hey everyone iam new here and i will be going to the new users section to post another thread but on this one i have just bought a 99 single cab 1500 4x4 with the 5.2 and i tried out my 4x4 today and it makes like a knocking noise when ever i give it a lil gas it doesnt make noise putting it into 4hi but when i start going and give it gas is when it makes that i plan on fixin it i just wanted to see if yall might have had the same problem... thanks
Old Sep 10, 2008 | 10:47 PM
dhvaughan's Avatar
dhvaughan
check the front drive shaft, its got that complicated double u-joint thing. there should be no play in any of the joints.
if its not obvious where the noise is coming fro, try to put it up on 4 jack stands and engage 4wd and safely inspect it while its turning.
Old Sep 11, 2008 | 10:03 AM
Aubrey's Avatar
Aubrey
Are you on pavement? Are you turning the wheel at all? What about in 4L? Does it happen reverse as well?
Old Sep 11, 2008 | 08:04 PM
99DRAM31887
yea iam on pavement... and i havent tried 4L and yea in reverse as well and while iam askin anyone know how to fix no reverse lights lol i have checked all fuses and replaced the bulbs but still nothing ......
Old Sep 11, 2008 | 10:12 PM
99DRAM31887
i tired it out in 4L but it will not let me engaged it unless it trucks off and not moving this is diff compared to my 99 durangos transfer case i had to be rolling at 5 mph to switch it but i can only engaged this one while the trucks still and when its in 4L it will hardly move and i cant disengage it or put the truck in park till i turn it off first if i try it grinds like nasty
