Turn Signals working when they feel like it
Old Sep 13, 2008 | 06:38 PM
dspitko1's Avatar
dspitko1
Default Turn Signals working when they feel like it
98 Ram Van 1500; Turn signals work then they don't work......and so on and so on. I will turn them on (doens't matter which signal I am using) and will work for about a minute then....nothing.......flasher is fine. GAAAHHHH The same will happen with the hazards.
Any suggestions?
Old Sep 13, 2008 | 06:56 PM
Sinister's Avatar
Sinister
check and re-seat fuses.
Old Sep 13, 2008 | 07:26 PM
dspitko1's Avatar
dspitko1
did that already...In fact it was the first thing I checked. Do I need to maybe replace a switch in the steering column?
Old Sep 13, 2008 | 08:02 PM
aim4squirrels's Avatar
aim4squirrels
electrical can be a real witch with a "B" to track down. I had a problem with the driver's side door lock intermittently working and then not working. It turned out the plug connector wasn't mating properly. I bent the male ends so that they would make a better connection to the female end and it's worked well since.
You might want to check if there is a loose wire coming into the fuse panel.
Old Sep 13, 2008 | 08:10 PM
dspitko1's Avatar
dspitko1
its funny that my electrical acts up when it get very humid. I am in the chicago area and it has been raining since yesterday. I did the good old fashioned hit the column....worked for about 30 seconds then back to working when they want to. I did check the wires going to the fuse panel and all seemed to be connected properly. I checked all the grounds (that I could see) and they are not corroded and connected the way they should be. I have the same issue with my brake lights at times....they work....don't work...stick on.....what a pain in the rear......
Old Sep 13, 2008 | 08:12 PM
aim4squirrels
dielectric grease
Old Sep 13, 2008 | 08:32 PM
dspitko1's Avatar
dspitko1
dielectric grease on what? the ground connections?
Old Sep 13, 2008 | 08:36 PM
aim4squirrels
anywhere you have a plug type connection, that'll help with the moisture problem.
talon6's Avatar
talon6
i had tail light and blinker problems until i replaced both tail light circut boards. after that no problems. under 20$ a piece from stealership.i had exactly the same symptoms.
Old Sep 13, 2008 | 08:38 PM
dspitko1's Avatar
dspitko1
circuit boards?....where would they be located.
Aim....thanks for the tip on the moisture issue I will do that tomorrow when I have some sunlight and maybe a rainless day..then again Ike will probably start here
