projector lights
Old Sep 21, 2008 | 10:05 PM
Viper37's Avatar
Viper37
Originally Posted by Kindschi
Also I can get plug and play HID kits (has everything you need) for 129.99. You littarly plug it into you stock socket and put the bulb in the housing. I have them on my truck (check sig) and they work great.. If your interested just shoot me a pm.
$129 for a low only 9004? I hope not, if so that's highway robbery. DDM's 35 watt kits start at $50. Bi xenon's for $125.
I have 3 of their kits in my truck. Good stuff.
http://ddmtuning.com/hidkihidbuhi.html
Old Sep 22, 2008 | 01:00 AM
nate_0022's Avatar
nate_0022
You can use regular halogen bulbs and also that's what is recommended for these headlights unless there TRUE HID headlights which they are probably not, most aftermarket headlights are only Halogen. If you want HID's search around ebay you can usually find some decent kits.
Old Sep 22, 2008 | 02:03 AM
Viper37's Avatar
Viper37
"TRUE HID"... What?
Old Sep 22, 2008 | 02:07 AM
jasonw's Avatar
jasonw
Site Moderator
I believe he is referring to a true "retrofit" headlamp designed for HID, as opposed to a headlamp or projector designed for halogen but fitted with a HID system.
Old Sep 22, 2008 | 10:51 AM
bizlebee's Avatar
bizlebee
ok i want to tap the halos/leds into the parking/running lights what and where is this wire located also in consideration the easiest place to locate this wire? please let me know what color this wire is too
Old Sep 22, 2008 | 02:09 PM
tresvatos's Avatar
tresvatos
Default 96 ram 4x4 w. Projector lights
You can look at my projectors in my pics. They look pretty awesome. I now have hid lights also. The ones in the pics are with the cheap blue bulbs. They still look good though.
Old Sep 22, 2008 | 04:54 PM
Kindschi's Avatar
Kindschi
To each there own, but in some cases you get what you pay for. If you like yours thats cool and im glad they work for you. I got Bosch and there awesome. I have them on my truck and motorcycle and never had any problems 100% waterproof too (some kits are not and burn up after the ballest gets alittle wet) But I was not willing to go cheap, too many horror stories of flickering bulbs and ballest burning up. Mine got a 3 year warrenty. Any problems I just send it back and get another sent out. I am intrested to see what the 5k's look like on our trucks, mind posting some daytime pics? Ill get some night pics of mine tonight and post em up.
Not trying to knock your choice Viper. And there are some kits that sell for 300+ in comparision 119 is not on the terribly expensive side.
BTW: My guys kits regular price 119.99 now.
Old Sep 23, 2008 | 11:42 AM
tresvatos's Avatar
tresvatos
Default Projector Lights
Here is a pic of my Ram w. the projectors. These have the cheap blue bulbs in them right now, but I have the HID kit going in whenever I get a spare second to install them.
Old Sep 23, 2008 | 02:43 PM
bizlebee's Avatar
bizlebee
ok guys i have them on and wired all up and they look good. i think im gonna take them somewhere to get aimed b/c i cant seem to get them high enough. ill put some pics on here a lil later. but i am having a prob with them now and i don't know what it is ok the projectors are bright really bright just way too low then the other beam when i switch to it u might as well be driving in the DARK! i bought some better bulbs today to see if it helps but i dont think it will they look the same to me still ( but it daylight out ) so maybe the plug and play isn't getting the amount of power to them? also the high beam light in my truck in the dash stays on even if i change between high and low beam lights. oh and when i change them to the low beam ( not the projector beam) the projector beam is still on just barely on. im thinking im having a power problem to the lights or its the plug and play. ill take pics of them tonight so u all can see what i am talking about
Old Sep 23, 2008 | 04:44 PM
nate_0022's Avatar
nate_0022
Here are the guidlines to help you aim you headlights. If you need help understanding let me know. Move back 25 feet from a wall on a flat surface. Measure headlights from the ground to the center of the projector, that's your projector height. Now from that height measure 2.5 inches lower that where you low step will be. Now measure the distance between your headlights, that going to give you the distance your cut offs should be apart.
Should look like this.
Should be using "C" to aim headlights.
This is how your headlights should look from about 50' back. Notice all the color on the left, and the actual light on the right, that is so you don't blind the on-comming drivers.
