air bag light
Old Sep 19, 2008 | 10:07 PM
mrsweet's Avatar
mrsweet
Default air bag light
The other day I was driving when I noticed my "air bag" light had come on. Since then it continuously goes on and off in intervals anywhere from 10 seconds to 2 minutes. Is this some sort of electrical issue? Any ideas how I can fix it? thanks.
Old Sep 20, 2008 | 11:12 PM
OZMarshy's Avatar
OZMarshy
Sounds like your clock spring is going these are a common fault. it is possible to change out yourself if you are happy to do it. I had the same problem changed the clock spring out and airbag light hasn't been seen since. just remember if you do it yourself to read the chapter on the replacement a couple of times so that you are comfortable with doing the change and follow all the warnings and cautions in the manual.
hope this helps
Marshy
Old Feb 8, 2009 | 05:35 PM
bigblockmopar419's Avatar
bigblockmopar419
OZMarshy my light jus came on light its the first time that it has done it since i have owned the truck!! where is the clock spring, wut manual are u talkin about, and how hard is it to change!?!?!? but in my truck it only does it when i brake and turn left at the same time!!!! i need some help guys!?!?!?
Old Feb 8, 2009 | 10:03 PM
dhvaughan's Avatar
dhvaughan
clock spring is under the steering wheel.
this manual...
http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Old Feb 16, 2009 | 12:04 AM
bigblockmopar419
this manual...
thanks dhvaughan i know its the clockspring now because my steerin wheel controls and my cruisecontrol wont work and my air bag light is stayin on now!!!!
