Reverse lights
Old Sep 21, 2008 | 11:04 AM
iwhitne's Avatar
iwhitne
same thing happened to mine... I just installed some after market lights under the bumper.... check out my photo gallery
Old Sep 21, 2008 | 01:26 PM
99DRAM31887's Avatar
99DRAM31887
mine arent working either i just got the truck a lil while back... so i dnt know how long they have been out but here in tx u dnt need them to pass inspection... but i want them fixed i was told to try replacin the neutral saftey switch
Old Nov 16, 2008 | 08:53 PM
thunderz's Avatar
thunderz
Nice ride! how do you like the headlight lenses?
Old Nov 16, 2008 | 08:57 PM
thunderz's Avatar
thunderz
Default no reverse lights
I have had the same problem since I bought the truck. They used to work a little with a wiggle of the shifter arm, but now there is nothing. Has anyone had experience fixing this issue? I remember reading in the manual how to fix it, but when I got under the truck, I couldnt see what they were talking about.
Old Nov 16, 2008 | 09:31 PM
dhvaughan's Avatar
dhvaughan
first, check the fuse, then the bulbs.
if no power to the rear lamps, then replace the 'reverse/neutral switch' on the side of the transmission. its in a hard to get to place, on drivers side, up near the front, behind the linkage. it has an electrical connector thats has a clip on it. 3 wires. if the clip is on the top, its hard as hell to get off. you have to slide a flat screwdriver up under the clip, from the back, in order to lift if off the peg. if you ever get the connector off, then the switch just unscrews. its available from autozone for about $25. if the electrical connector is full of dirt, try cleaning the contacts and plug with wd40 before you replace the swtich. also, if you remove the switch, see if the inside can be cleaned to make it work again.
Old Nov 16, 2008 | 09:54 PM
Laramie1997's Avatar
Laramie1997
you know i never really looked until now, I went out and checked and sure as **** my reverse lights dont work either, checked both bulbs and the fuse and nothings bad hmm might have to do some looking
Old Nov 16, 2008 | 10:27 PM
dhvaughan's Avatar
dhvaughan
DIAGNOSIS AND TESTING - PARK/NEUTRAL POSITION SWITCH
The center terminal of the park/neutral position
switch is the starter-circuit terminal. It provides the
ground for the starter solenoid circuit through the
selector lever in PARK and NEUTRAL positions only.
The outer terminals on the switch are for the backup
lamp circuit.
SWITCH TEST
To test the switch, remove the wiring connector.
Test for continuity between the center terminal and
the transmission case. Continuity should exist only
when the transmission is in PARK or NEUTRAL.
Shift the transmission into REVERSE and test
continuity at the switch outer terminals. Continuity
should exist only when the transmission is in
REVERSE. Continuity should not exist between the
outer terminals and the case.
Check gearshift linkage adjustment before replacing
a switch that tests faulty.
REMOVAL
(1) Raise vehicle and position drain pan under
switch.
(2) Disconnect switch wires.
(3) Remove switch from case.
INSTALLATION
(1) Move shift lever to PARK and NEUTRAL positions.
Verify that switch operating lever fingers are
centered in switch opening in case (Fig. 187).
(2) Install new seal on switch and install switch in
case. Tighten switch to 34 N·m (25 ft. lbs.) torque.
(3) Test continuity of new switch with 12V test
lamp.
(4) Connect switch wires and lower vehicle.
