question about rear axle
Old Oct 2, 2008 | 07:45 PM
2000ram1500's Avatar
2000ram1500
Originally Posted by zman17
The first problem is you don't want to remove the pinion nut! Do you mean you took out the drive shaft to remove that nut?
no i took the differential cover off and took the slide pin bolt as the guy posted after. and i cant get the slide pin to move at all.
Old Oct 2, 2008 | 09:55 PM
dodgeguy97's Avatar
dodgeguy97
small hammer start tapping sounds like its burred up not much room to work with but you will get it keep working with it sorry i don't care for those haynes manuals
Old Oct 3, 2008 | 06:55 AM
2000ram1500
i just bought the haynes for a general idea of what i was doing since this is a big project for me. ill try that today that if i get home from work. thanks for the help
Old Oct 3, 2008 | 04:27 PM
dodgeguy97's Avatar
dodgeguy97
sorry i didn't mean to sound so blunt but i hope it works for you
Old Oct 3, 2008 | 06:24 PM
dhvaughan's Avatar
dhvaughan
no special trick for the pinion shaft.
completely remove the lock bolt,
then rotate it around where you can get at the end of the shaft.
use a block of wood and hit it a hammer.
its snug - but it should slide right out.
Old Oct 13, 2008 | 03:32 PM
2000ram1500
just taking a short brake from working on my truck. i got the pinion shaft out. c clip for the axle/ axle out. backing plate off new one on and now im just putting it all together. thank you for the help and i will be posting pictures really soon.
Old Oct 13, 2008 | 05:42 PM
dodgeguy97's Avatar
dodgeguy97
glad its working for you good luck
Old Oct 13, 2008 | 06:05 PM
2000ram1500
ok now after im done for the day here is my update of what is left.
i have to assemble the back brakes, put fluid in the axle, bleed the brakes, get a new bumper, new headlights/corner lenses to, and im pretty sure i have to get a new steering box. when i last drove the truck i had to have the wheel turned 90 degrees to drive straight. and its the second time i have had it happen and last time it was the steering box. any other ideas what it is?
Old Apr 28, 2009 | 01:43 AM
nolazach's Avatar
nolazach
How do you remove the carrier?
Does it just pull out, or do you need a special tool?
