question about rear axle
Old Sep 21, 2008 | 08:38 PM
2000ram1500's Avatar
2000ram1500
Default question about rear axle
i was wondering if someone could help me out with a how to for dissasembling the 9 1/4 rear axle. i need to get the drivers side axle shaft out to replace the backing plate.
Old Sep 21, 2008 | 08:52 PM
dhvaughan's Avatar
dhvaughan
the procedure w/pics is in the haynes manual and the service manual.
it goes something like this.
put rear end up on jack stands.
remove tires/wheels.
remove cover and drain oil.
rotate carrier around until the pinion shaft lock bolt is accessible.
remove pinion shaft lock bolt. one bolt about 8-10mm
slide pinion shaft out. spider gears in top/bottom are now unsupported, so don't rotate the wheels.
slide axle in. pluck c-clip off the end of the axle.
slide axle all the way out.
Old Sep 21, 2008 | 09:02 PM
2000ram1500
wow i feel like an idiot ive been reading the haynes book back and forth trying to find it and as soon as you said that i found it. its 8-12 under 14 right just double checking before i dig into it since i want to start tomorrow.
Old Sep 21, 2008 | 09:47 PM
dhvaughan's Avatar
dhvaughan
8-12-14 yes, with pictures at the top. good luck, its not hard. when you put it back together put a little threadlocker on the pinion lock bolt.
Old Sep 30, 2008 | 04:01 PM
2000ram1500
well i started to disasemble the drum breaks and hit a snag. i cant figure out how to take the emergency brake off the backing plate and the shoe. can anyone help out?
Old Sep 30, 2008 | 05:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
After you remove all the springs and the pin going through the back plate and the shoe is free, just twist it and the cable will come off. This is also in the Haynes manual. And also only do one side at a time, this way you can look at the other side to see how too put it back together.
Old Oct 2, 2008 | 03:54 PM
2000ram1500
thanks for the help zman17. i got it right out after i tried it.
now i have a new question. i have to get my drivers side axle shaft out and i got all the way to remove the lock bolt from the diferential pinion shaft and remove the pinion shaft. my problem is i cant get the pinion shaft to move. any help on how to get it to come out. any tricks to get it out.
Old Oct 2, 2008 | 05:48 PM
zman17's Avatar
zman17
The first problem is you don't want to remove the pinion nut! Do you mean you took out the drive shaft to remove that nut?
Old Oct 2, 2008 | 07:01 PM
dodgeguy97's Avatar
dodgeguy97
i was wondering after reading this you shouldn't be messing with the pinion nut to remove the axel shaft all you need to do is remove the spider gear slide pin and slide pin bolt push in on the axel knock the c-clip off and pull out the axel
Old Oct 2, 2008 | 07:44 PM
2000ram1500
i was reading right from the haynes manual when i was writing in the last post. i loosened the slide pin bolt (pinion shaft as haynes calls it) and pushed on the slide pin and it didnt move at all for me. is there a trick to get it out?
