Brakes Burn Hot on Dodges?
Old Oct 2, 2008 | 02:01 PM
  #21
Dodgeman000's Avatar
Dodgeman000
So would a Break setup from a 00 01 directly bolt up to a 99? Or would I have to get new steering knuckles to?
Old Oct 2, 2008 | 02:11 PM
  #22
hometheaterman's Avatar
hometheaterman
I like you guys go through front pads like crazy. I mean I get like 15-20k miles out of them. The first set was Raybestos and was worn out in that time. The second set was Chrysler OEM pads which seemed to wear better but I took them off to grease them up after hearing squeeking and they were all cracked so I put Raybestos pads back on. Higher end ones this time not the cheap ones. We will see how they do. They stop okay. Not the best but okay the pads just don't last. I have some Hawks I didn't get in time due to a mix up at Summit I kept for my next brake change so I will see how those are next.
Old Oct 3, 2008 | 08:58 AM
  #23
HankL's Avatar
HankL
Bendix pads, shoes and drums have worked well for me
over the original equipement
and over Dodge's official upgrade kit for 1994 to 1996 Rams
but I have a 1995 with the Delco brakes
The Hawk pads get consistently good reviews,
and I have a set waiting to go on
EGR Brakes is one company offering upgrades:
http://www.pavementsucks.com/showcase/bigcaliper.php
http://www.egrbrakes.com/index-main.htm
Fred Goeske is best known for wheel adapters
but is also a true brake expert and craftsman
http://www.wheeladapter.com/fred_goeske.asp
Old Dec 5, 2009 | 01:01 PM
  #24
TIMIDONE's Avatar
TIMIDONE
Okay bringing this thread alive again...hopefully.
My number one thing I hate about my truck...the brakes! Here we go again.
When I brake now I hear a scraping sound. I know what that means cause it happened to me before...warped rotors. I just replaced the dang thing less than 10 months ago!
Anyway...I searched but did not find a DIY to replacement my brake to larger brake system. Anyone got any links? I don't want to just replace I have to upgrade to a larger brake system.
Thanks in advance.
Old Dec 5, 2009 | 01:17 PM
  #25
iwhitne's Avatar
iwhitne
I would get the EBC Sport rotors and green stuff pads... that's what I did.. very easy to install
Old Dec 5, 2009 | 01:33 PM
  #26
offroadjosh's Avatar
offroadjosh
I am also interested in upgrading my front brakes... I put the 1ton cylinders in the rear now i want better brakes up front. I really don't trust my brakes in an emergency stop.
Josh
Old Dec 5, 2009 | 03:44 PM
  #27
TIMIDONE's Avatar
TIMIDONE
I really hate to ask a dumb question but are those larger than stock? They look about the same form what I can see in pic. I was thinking of actually going larger...I think our braking system is just too small for our truck and especially for me with all the steep mountains I hunt in.
Old Dec 5, 2009 | 04:57 PM
  #28
hometheaterman
Thanks in advance.
Yeah these brakes suck on this truck. I just had to replace mine the other day again also. I'm not saying they don't stop decently as they do. Not great but decently. Better than some other trucks I've driven. However, the pads just don't last on these things.
BTW where did you get those EBC rotors? What did they cost you?
Old Dec 5, 2009 | 06:43 PM
  #29
dsertdog56's Avatar
dsertdog56
I realize this is an old thread but perhaps I could make a suggestion or two.
You could probably change over to 2000 up front brakes if you get the proper rotors and if you can bolt the caliper mounting rail to your hub.
After doing so, you will immediatly notice your brakes are no better than your old ones.
After going through several sets of pads...and I use H.D. Raybestos "Super stop" pads because they WILL stop my truck, I descovered a simple secret that improves my braking exponentialy. Here it is.
About every other oil change which (for me) occurs every 3 months or 3000 miles, I crawl under my rear bumper and pull the adjusting star covers off the backing plates. After popping off the rubber covers, I use a flashlight and screwdriver to check the rear brake adjustment.
It is amazing how many turns it will take sometimes to take out the slack. In fact, I can usually tell by my braking when I need to do it.
Now you can certainly spend a ton of money updating to uber trick pads and rotors, but all you're really doing is masking the issue.
Seriously...check your rears, before blaming your fronts. Oh, and if you're gone through 2sets of pads and haven't touched your rears, that should be a clue.
Old Dec 6, 2009 | 11:15 AM
  #30
redheadhunter21's Avatar
redheadhunter21
On my 96 I changed to the 2500 brake calipers and it made quite a difference in braking I also run autozone's ceramic brake pads they make no noise but I still get some break dust but Ill live with it
