Tranny servce Qu's
Old Oct 2, 2008 | 06:42 PM
dodgeguy97's Avatar
dodgeguy97
one of the big problems is the 2-3 shift spring almost every one of them break and no one fix's them sometime's you don't know there broke until it takes out other parts with it
Old Oct 2, 2008 | 07:15 PM
MonteC's Avatar
MonteC
What are you talking about?
Old Oct 2, 2008 | 07:32 PM
Viper37's Avatar
Viper37
make sure the filter kit comes with the plastic gasket not cork the cork gasket is too thin which puts trans pan closer to the filter and always leak as for trans fluid atf+4 only ur trans will last longer and operate better
Holy punctuation Batman.
Old Oct 2, 2008 | 09:36 PM
MonteC's Avatar
MonteC
Plastic? Some stockers came with a rubber bonded metal pan gasket. If that is not available then i would go with a "Farpack" gasket, they are a laminated paper type gasket material, its a super effective material.
Cork wont always leak, you just need to toque the gasket correctly.
