How to install transmission temp gauge?
Old Feb 24, 2020 | 08:39 AM
  #31
Itchybruno74's Avatar
Itchybruno74
Originally Posted by padodgeram
You can use the front servo port to get the temp reading plus autometer will come with the hardware to install in the servo port If you have downloaded the (merry christmas ) PDF scroll the trans section and it will give the servo ports , Easy DIY....
Where can I find the merry christmas (?) PDF? A link please?
Sorry to kick at an old thread. That's what happens when you use the search....🍻
Old Feb 24, 2020 | 08:44 AM
  #32
The name got changed. Thread is here.
Old Feb 24, 2020 | 02:54 PM
  #33
MoparFanatic21's Avatar
MoparFanatic21
Veteran: Marine Corps
Servo port won't give you an accurate reading
Old Feb 25, 2020 | 08:15 AM
  #34
HeikIlm's Avatar
HeikIlm
Yep, servo port gives more of a housing temperature than oil temp. Oil can get really hot before port mounted sensor reacts to that. Either bung to the oil pan and sender to there, or to the line that goes to the oil cooler.
Old Feb 25, 2020 | 10:34 AM
  #35
Itchybruno74
Appreciated. Thank you
Old Feb 25, 2020 | 10:35 AM
  #36
Itchybruno74
Fair enough. Heard this a couple times now since I've been researching. Thank you.
Old Feb 25, 2020 | 02:42 PM
  #37
MoparFanatic21
Glow shift gauges makes a compression fitting to go on the line I think it's around $20. I'm going to install two temp gauges one before the cooler and after and have one gauge read both.
