Spark Plug Wires
Old Oct 19, 2008 | 09:54 AM
GolfAddict's Avatar
GolfAddict
Default Spark Plug Wires
I have the MSD 8.5 wires on my truck, how often should i change these out? They have been on for about 6 years? Also where can i find upgraded cap/rotor?
Old Oct 19, 2008 | 11:00 AM
aim4squirrels's Avatar
aim4squirrels
steve05dodgeram630 swears by the mopar performance cap and rotor.
Inspect the wires for cracks in the protective coating and poor connections at the terminal crimps. If they check out, reuse them.
Old Oct 19, 2008 | 12:05 PM
dodgeguy97's Avatar
dodgeguy97
summit racing has brass contact cap and rotor $23.00 i gonna try it out .
Old Oct 19, 2008 | 12:20 PM
lastrights's Avatar
lastrights
dont get summit, had that on mine, and tore up the rotor so bad , i still have the thread somewhere on here.
Old Oct 19, 2008 | 12:21 PM
lastrights's Avatar
lastrights
https://dodgeforum.com/forum/showthr...t=summit+rotor here it is
Old Oct 20, 2008 | 07:23 AM
HankL's Avatar
HankL
i just pulled and changed the distributor cap and rotor using the Napa brass contact ones,
and measured my Magnecor wires after cleaning them.
I was very impressed that the Magnecor CN125 wires still measured the same ohms and showed almost no heat damage to the silcone insulation, and very little physical damage
.... and this is after ten years and 155,000 miles
Old Oct 20, 2008 | 10:16 AM
Silver_Dodge's Avatar
Silver_Dodge
I like the Napa cap/rotor with brass terminals. You can test your wires and inspect them for signs of craks or burns. Probably be fine to reuse them. Defiently replace cap/rotor though, that is what will be worn out.
Old Oct 20, 2008 | 10:30 AM
talon6's Avatar
talon6
i used the borg warner,nascar select with brass cap and rotor. seem to be pretty good so far. just make sure they are brass. better conduction with less corosion.
