additional parts??
Old Oct 22, 2008 | 02:30 AM
dodgeman22's Avatar
dodgeman22
Default additional parts??
hey guys i have a buddy with a lathe that can make me coil spacers and blocks for my truck im thinkin 3 or 4 inches, and i was wondering if i need additional parts, i know shocks are a must but is there anything else needed?? i would need to extend my axle breather line and such but anything else thanks in advance
Old Oct 22, 2008 | 09:50 AM
pcfixerpro's Avatar
pcfixerpro
If you stay 3 or under, I don't think you need drop pitman arms, or drop trackbar brackets, upper and lower control arms etc. No offense, but it is probably easier to buy the materials than make them youself? You still need to buy ubolts, nuts, etc if your going to do blocks anyway. Also, how do you plan on installing the studs in you spacer? Seems like a lot of work for something so simple that you can pick up for cheap anyway. a 2.5" spacers is 80 dollars at www.hellbentsteel.com You can buy 3" coil springs if you want which I think the part number is D30 from skyjacker. Whatever you want to do, wish you luck!
