interior light not working
Old Nov 2, 2008 | 07:48 AM
APA228's Avatar
APA228
If the cargo lamps are working pull the dome light down and gently pull the wires toward you. You should have some slack in the harness. Try right at the center contacts in the bulb socket and test for voltage from the pink wire contact. If you have voltage there check the yellow wire contact for continuity to ground. This can be with the headlight control set to put the light on or with a door open so the light would be on. You could just have bad/dirty contact from them to the bulb. If that is the case polish the contacts by taking a pencil eraser and rubbing them down with it. I hope this works for you.
Old Nov 2, 2008 | 09:20 PM
Keegan's Avatar
Keegan
I'm starting to think one of the two wires is bad up there... both contacts are nice and clean, and I didn't get voltage off the pink wire, possibly because the yellow wire is a bad ground? I will test again and put the negative probe to something other than the yellow socket.
Old Nov 3, 2008 | 10:25 AM
APA228's Avatar
APA228
Did you get continuity to ground on the yellow with the switch on or the door open? If you did, don't worry about the yellow wire. The pink wire supplies both the dome and cargo lights and should be hot at all times. The dome light feed splices into it and is a just a short run from the light to the wire. You should be able to see it if you drop the overhead console down. Be careful taking it down since there are 2 screws and hidden clips holding it up. You can re-splice the dome light feed to the pink wire feeding the cargo lights above the headliner .
Old Aug 9, 2009 | 11:21 PM
Keegan's Avatar
Keegan
Big bump here!
I removed the lower dash panel, and there is a plug housing the pink and yellow wires, and its NOT PLUGGED IN! The problem here is, I tried to find a socket but I cant! help!
Old Aug 22, 2009 | 12:11 PM
Keegan's Avatar
Keegan
Okay. So I went to the wreckers to pick up a new headliner and a console ( my truck didn't come with a console) Took out the wiring harness that goes to the console, and it plugs in to the yellow and pink wires that weren't connected to anything under the dash. So I know where the console plugs in. I looked a little more at the wires coming down from the single interior light down along the kick panel and underneath the dash, and it seems like they go in to some big harness thats all taped up. If the little dome lights don't work either once its hooked up, I don't know what I'm going to do LOL.
Old May 9, 2015 | 06:33 PM
dodgemike13's Avatar
dodgemike13
I have a problem.i have a 2000 dodge ram 1500, I installed anew cd player, but it does it does not work and also now my dome light don't work.. what would be the problem???
Old May 9, 2015 | 09:40 PM
Check the IOD fuse first. (it's the one with the pain in the keester plastic cover.) If it's blown, need to find out why. (my guess, the radio install has something to do with it.)
Did your truck come with the infinity system?
Old Aug 7, 2017 | 08:54 PM
Zach Newport's Avatar
Zach Newport
Originally Posted by APA228
If you can't get it to light with the light switch on the dash don't waste your time pulling the door switches. The dome light operates by being grounded and if none of the switches turns it on there is either no feed to the light or the ground connection to the light is disconnected. Check fuse #12 which should be the feed fuse. If it is good pull the dome light and check for 12 volts on the pink wire which is the hot feed to it. Also check for continuity to ground on the yellow wire.
Fuse 12 is in the fuse panel in the dash right?
Old Aug 7, 2017 | 09:52 PM
Yep. Under a clever little cover.
