weird pinging issues...need help.
Old Jan 5, 2009 | 09:50 PM
  #181
dhvaughan's Avatar
dhvaughan
still pinging ?
cel still flashing ?
Old Jan 5, 2009 | 09:56 PM
  #182
aim4squirrels's Avatar
aim4squirrels
Still pings, can't get the CEL to flash again.
Need to see about doing a compression test at this point, I think. EVERY sensor that could cause this has been replaced at some point.
Old Jan 5, 2009 | 11:36 PM
  #183
minis2003's Avatar
minis2003
i installed at home made oil catch can like you did and it works great. it prevented alot of oil from going into the intake had to empty it once so far (3,000miles). i use to get ping under part throttle but now now more.
i installed the oil catch can, ran 2 tankfuls(35gal) of Seafoam (two cans per tank) and use carb. cleaner to clean the sensors and down the throttle body and that stopped the ping.
i since then installed at MSD-6A with Autolite XP (XP3924) gapped to 0.50 now it idles alot soother and no ping under part or full throttle
Old Jan 6, 2009 | 11:08 AM
  #184
steve05ram360's Avatar
steve05ram360
get your fuel sync checked...
what coil are you running again?
Old Jan 6, 2009 | 12:18 PM
  #185
dodgeram07's Avatar
dodgeram07
did you set the cps mod back to stock...just thinking
Old Jan 6, 2009 | 12:21 PM
  #186
zman17's Avatar
zman17
Retired Moderator - RIP
Yes he did, I was wondering that myself.
Old Jan 6, 2009 | 11:20 PM
  #187
aim4squirrels
MSD Blaster 3 coil. and I also slapped the stock coil on and bypassed the 6A box. The ingintion system is fine I believe.
Old Jan 8, 2009 | 09:38 PM
  #188
aim4squirrels
Well, Here's the result of the compression test I ran. I'll list them by adjoining cylinders for ease:
#8: 165 #7: 165
#6: 158 #5: 161
#4: 155 #3: 161
#2: 160 #1: 159
So I'm not losing compression. IDK if a leak down test would tell me anything if the compression test checks out.
Old Jan 9, 2009 | 08:51 AM
  #189
steve05ram360
your still debugging a problem you had prior to the manifold swap, whatever it is, it effects all cylinders and not 1. you need to look for problems that will effect all cylinders. Cranks sensor, cam sensor (fuel sync), vacuum signal (what happens under load to it... any fluttering or is it solid), fuel pressure under load (is it holding to spec under high demand?)
and lastly... did you grease the hydrolic flux inductor? <jk>
Old Jan 9, 2009 | 09:04 AM
  #190
Rex-TheDOGG's Avatar
Rex-TheDOGG
Your compression numbers are good and even. I don't think a leak down test is going to tell you anything more. Based on the story so far, we know that the pinging stops when the octane is raised and/or timing is retarded, correct? Can you view your ignition timing settings with your SCT?
