weird pinging issues...need help.
Old Jan 2, 2009 | 12:57 AM
  #171
dodgeram07's Avatar
dodgeram07
wow looks great, i've alway wanted to set my truck up like yours.. rr,tb,e-fans,hv pump,gears...ect .........but this just push the bar to high.lol... nice job on this project
Old Jan 2, 2009 | 09:23 AM
  #172
aim4squirrels's Avatar
aim4squirrels
It's not too high, just get after it. I learned all sorts of little tricks doing this install:
2. Coolant temp sensors can't be torqued very tightly at all.
1. If you need to drill or tap into the water jacket while it has coolant in it you can quite easily. Just coat the drill bit or tap in really thick grease and the flakes from the drill or tap will stick to the bit and the coolant will push out any extra bits.
2. If you can't get the tap handle into position to tap a hole for threading (they sometimes can be quite large) you can use a 12 point socket that fits the tap end and start it by hand before you go to the ratchet. It works great!
3. There's a small tab on the accessory bracket (not the "front" tab, but that also needs to go) that makes removal of the T-stat housing difficult. If you grind it down, the T-stat housing comes up and out pretty as you please.
4. PB Blaster makes a great fuel injector O-ring lubricant.
5. Nickel anti-seize is your friend.
6. Never drink Diet Mountain Dew while working with antifreeze.
The Hughes kit was $730 bucks, If your looking to upgrade your intake, I recommend it.
Old Jan 3, 2009 | 01:53 PM
  #173
aim4squirrels
Default Squirrel's gone wild!
I think I finally have this one nailed down! (sprints to cabinet and knocks on wood feverishly).
The ping returned after a few miles on the new intake, last night I had a misfire on the highway and I freaked! I replaced the IAT, the MAP sensor, Crank Position Sensor, swapped out the T-stat for a 180* and it still pinged.
In a last ditch effort, I remembered that had not run a can of MCCC. I pulled the #7 plug just to check it, It was BLACK around the bottom threads with carbon and the tip was sightly deformed. Pulled them all and they looked horrible (especially for only about 6K on the plugs):
Those might be hard to see without a Zoom feature, but trust me they were spent.
So, I replaced them with the set of NGK Iridiums I had been hanging onto for after I fixed this issue, The engine ran like butter! NO MO PING! I've just run a can of MCCC to clear out the combustion chamber.
I wasn't done there. I got to feeling like there was too much PCV blowby, so I went to Home Depot and picked up a Air compressor fiilter, brass fittings, and some tubing for about $40 and fabbed up a catch can for the PCV.
I'll be checking up on it to see what I catch. Here's a pick installed:
I hope I'm done with this issue
Old Jan 3, 2009 | 02:50 PM
  #174
dodgeram07's Avatar
dodgeram07
i hope you are too
Air compressor fiilter good idea.... and zip ties can be your best freind sum times
Old Jan 3, 2009 | 03:12 PM
  #175
Rex-TheDOGG's Avatar
Rex-TheDOGG
LOL, Squirrels that is the same water separator I have on my compressor set up. Don't know for sure, but I think they are only separate water from a positive pressure air stream. Not sure how that will work under negative pressure and trapping oil. I think that's going to defeat your PCV system.
Old Jan 3, 2009 | 03:17 PM
  #176
dhvaughan's Avatar
dhvaughan
one way to find out... dunk the pcv in a cup of oil while running. see if the oil ends up in the filter, or passes through.
  #177
aim4squirrels
PCV is positive crankcase ventilation. It should work, if there's excessive oil.
I just got the Flashing CEL again while driving (12 flashes) but I sure didn't feel a miss.
What the hell is going on? I'm going nuts here.
Old Jan 3, 2009 | 10:21 PM
  #178
lv360ram's Avatar
lv360ram
If you got the flashing CEL after installing the new plugs, and if the flashing CEL means multiple misfires then it seems like the problem would be wiring related, like the wiring from the computer to the coil or an intermittant ground connection.
With all the things you have fixed on your truck, you may be able to start a business fixing Dodge trucks that the dealerships can't fix.
Old Jan 3, 2009 | 10:40 PM
  #179
aim4squirrels
LOL, if only I could fix my own!
Old Jan 5, 2009 | 09:33 PM
  #180
aim4squirrels
The catch can seems to be working, I had about a spoonful in the bottom today.
